Help with two minor electrical problems !
Old Apr 29, 2008 | 08:20 AM
nc150's Avatar
nc150
My 86, 150, 4x4 with the 4.9 ....bone stock
in dash voltmeter and temp guage don't work....Where is the temp sender on the engine ? and where do you think I should look for the volter meter problem?
Thanks all
Old Apr 29, 2008 | 09:47 AM
uncle.stosh's Avatar
uncle.stosh
I would take the cluster out and clean the contacts first before assuming that it's a sensor problem. You may also just have a loose connection at the main plug.
Old Apr 29, 2008 | 04:09 PM
ri_truck_guy's Avatar
ri_truck_guy
Disconnect the temp sensor wire at the sensor and ground it with the ignition in the run position. If memory serves me right the sensor on the 4.9 will have a single push on red/white wire and be located at the lower driver side on the front of the block. If you ground the wire and it swings all the way to hot, the wire and gauge are working fine and the sensor is bad, If the gauge doesn't move when grounded, it's a wiring/connection/gauge problem. Start with cleaning the connections as Stosh suggests.
The voltmeter is a little trickier, but I would start by cheking the gauge itself. It has two metal pins that go through a plastic sleeves that secure it to the cluster. These plastic sleeves are notorious for breaking. Also, check your altenator wiring for loose or broken connections.
Old Apr 29, 2008 | 05:57 PM
Holmesuser01's Avatar
Holmesuser01
Every 4.9 six I have ever seen have the temp sender located at the back of the engine at the firewall on the passenger side of the block under the exhaust manifold.
The ammeter problem is another problem. Is the system charging OK otherwise?
Old Apr 29, 2008 | 06:46 PM
ri_truck_guy
That's probably true...as I said I was going from memory at the time and it's been a good 3 years since I've owned a 4.9, and that one was much newer. The test process doesn't change though.....
Old Apr 29, 2008 | 08:18 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Temp sender located at the back of the engine on the passenger side, just as Holmesuser said.
Circut #39 Red/white stripe wire.
there are three conections for this wire.
Connector #208 at the instrument cluster P.C. board.
Connector #325 at the driver side fender.
And of course, Connector #310 at the sender.
The voltmeter is actually an Ammeter, and is quite different in operation to a voltmeter. Start the truck and watch the ammeter, and rev the engine. If it moves toward the charge side slightly it is working. Turn the heater blower, headlamps on etc, and if it moves toward the discharge side, slightly, it is working. The ammeter does not read very much off the center of the gauge, unless something is wrong, like a dead battery, or bad altenator. So if you don't see it move, but only slightly, then that is normal.
Old Apr 29, 2008 | 08:26 PM
ri_truck_guy
Is the #325 driver side fender the connection from the engine harness to the underdash harness, or something else?
Old Apr 29, 2008 | 08:29 PM
ri_truck_guy
And does the oil pressure sender wire go through the same #325 connection?
Old Apr 29, 2008 | 09:45 PM
81-F-150-Explorer
Yes indeed, it does. It's one of the engine harness, to main harness connectors.
Circut #16 red/lt. green wire, (that goes to the coil, also goes through connector #325.
ford coonhunter
1997 - 2003 F150
Aug 26, 2012 09:33 PM
lbg2004lariat
2004 - 2008 F150
May 27, 2009 06:55 PM
John Luther
1997 - 2003 F150
May 12, 2008 10:53 AM
tawd77
Feb 5, 2007 08:17 PM
FordF1502WD
Apr 20, 2003 05:59 PM
