Water Temp. sending unit
Old Apr 19, 2003 | 04:01 PM
FordF1502WD's Avatar
FordF1502WD
Lightbulb Water Temp. sending unit
I've got a problem with my 94 F150 Water temp. gauge. I'm not getting a indication. I think it's the sending unit. It's on the 4.9 (6 cylinder) motor. But I can't find that little dude........
Where is it............
Old Apr 19, 2003 | 06:07 PM
kioolt's Avatar
kioolt
There are two temperature sensors on the truck. One is for the gauges and the other is for the engine control. The one for the gauges is located on the right side of the engine and will have a red/white wire on it.
Old Apr 20, 2003 | 09:38 AM
FordF1502WD
OK that's great news.. the right side facing the truck? I replaced the oil sending unit that was bad on the lower back side of the engine block on the drivers side. I see the sending unit to the engine control next to the distributor. But for some reason I still can't find the other sending unit.....
Old Apr 20, 2003 | 09:44 AM
larry derouin's Avatar
larry derouin
Kevin; The gauge sending unit is on the HEAD! Back (REAR) of the Engine on the PASSENGER (RIGHT) side of the engine, BELOW the Intake/exhaust manifold ports for #6 cylinder.
Pull the wire off and with the key to ON (not start), ground the wire. If the gauge swings to the opposite side (overheated) then the gauge is good and the sending unit bad. If the gauge doesn't move the gauge or wiring to it is bad, worn, corroded.
In any event the sensor is cheap (<$5.00) so it's cheap insurance to go ahead and get it anyway.
Make sure all grounds are clean and shiny, and if any look iffy, replace the wire and connectors.
Larry
Old Apr 20, 2003 | 02:21 PM
kioolt's Avatar
kioolt
It's on the right side looking at the truck if your looking at the back of the truck. When someone refers to which side something is on a vehicle, they should be telling you right for passenger side and left for drivers side. That is the universal standard.
Old Apr 20, 2003 | 03:20 PM
FordF1502WD
Hey Larry, Thanks for the tip... I'll check it out
Old Apr 20, 2003 | 05:59 PM
steve83's Avatar
steve83
L & R on a vehicle is always from the operator's point of view.
Long Haul
6.2L V8
May 26, 2015 09:34 AM
WarOzz
17
Dec 29, 2012 05:50 PM
1978fordf250
Sep 7, 2010 09:52 PM
Gage2502
Modular V8 (4.6L, 5.4L)
Feb 25, 2008 07:34 PM
dbrown13
Dec 30, 2003 09:06 AM
