Turn signal not working
Old Apr 29, 2008 | 01:07 AM
65f100_352's Avatar
65f100_352
On my 78 F250, all but one of the bulbs are working, the front drivers side. The rear lights up, but no front. the passenger's side works just fine as do my hazards, except the driver's front. I have checked the ground and it is good as is the bulb, and the socket isn't corroded. Also I do not have front parking lights. The side ones and tail lights work, but not the front parking lights. Any help would be much appreciated!
Old Apr 29, 2008 | 01:53 AM
djangoism's Avatar
djangoism
On a related note regarding turn signals, on a '73, are they supposed to auto-cancel after making your turn? Mine don't...
Old Apr 29, 2008 | 06:26 AM
Metallheadd's Avatar
Metallheadd
My left turn signal also doesnt cancel but the right does.
Old Apr 29, 2008 | 10:28 AM
Hillcrest#9's Avatar
Hillcrest#9
65f100_352 When I built my 76 I had one light ( drivers front signal ) that did not work. Found a bad connection at the bulk head connector under the dash. Sniped the wires on both sides of that connector and ran a new wire with connector along side the main connector and all was good from then on. djangoism and Metallheadd You guys just need to replace that white or black nylon ( plastic ) signal switch under your steering wheels. Cheap and easy to do. I let my 12 year old grandson change mine, He got it right with no help from me.
Old Apr 29, 2008 | 11:14 AM
highboy250's Avatar
highboy250
My last F250 didn't auto cancel the turn signal after a turn, and I loved it! The Ranger always cancels out before I even make my turn, and it drives me nuts. Then again, I like having everything manual, and doin' it myself. Gonna turn mine manual when I change my steerin wheel. Could probably send the piece to one of ya.
But as far as the turn signal, hopefully Hillcrest answered your problem. Mine are confusing me though. They weren't working. Replaced the flasher, they worked. Then only the left turn signal would work. Got them properly grounded. Then only the right turn signal would work. Last night tested it, and now only the left turn signal is working. What gives? lol
Old Apr 29, 2008 | 01:18 PM
65f100_352's Avatar
65f100_352
Thanks everyone thats a good idea, Hillcrest. I will try that when it quits raining.
Mustangking1
27
Oct 30, 2013 09:33 PM
mdbbrown
Dec 28, 2012 01:26 PM
vol1966
Feb 20, 2011 11:01 AM
blockmanjohn
Electrical Systems/Wiring
Mar 14, 2010 04:49 PM
2002f2507.3LPS
Sep 10, 2007 10:06 AM
