Wasn't the Bulb
Old Mar 13, 2010 | 11:41 AM
blockmanjohn's Avatar
blockmanjohn
Wasn't the Bulb
My driver's side front parking light doesn't work. I changed the bulb, but to no avail. Any ideas where to start looking. Thanks, John
Old Mar 13, 2010 | 01:56 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Remove bulb.....eyeball the socket....any rust? Use meter or test light and see if you got power to it. Report back.
Old Mar 13, 2010 | 06:50 PM
Franklin2's Avatar
Franklin2
If it's the running light(comes on with the headlights), it's going to have to be the socket or the wiring connections in that area. All the running lights are fed by a common brown wire, so if one side works and one side doesn't, that means a good portion of the brown wire circuit under the hood is good, and only one section has a problem.
Old Mar 14, 2010 | 12:11 PM
blockmanjohn
Thanks for all the advice. I have 12+ volts on the signal light prongs of the connector, and 0 volts on the parking light side. I guess the next step is to test the brown wire before it enters the connector. Thanks again, John.
Old Mar 14, 2010 | 04:49 PM
blockmanjohn
I found the problem. When they installed my snow plow they spliced another brown wire to the parking light wire to feed the plow lights. They used a crimp connector with shrink wrap over it. It corroded and separated inside the wrap. Thanks again for all your help. John
jhsilcox
May 7, 2014 05:52 AM
John7894
Mar 8, 2013 08:54 AM
John Morton
Sep 30, 2012 03:57 PM
John Morton
Mar 18, 2012 12:24 PM
blockmanjohn
Mar 13, 2010 10:24 AM
