460 fuel pump?
Old Jun 27, 2013 | 11:03 PM
thornton1979's Avatar
thornton1979
460 fuel pump?
Ok i have a small problem. I put gm hydro boost on my truck. And i used a saginaw pumo. I couldnt find any 460 saginaw pump brackets. So i hot an aluminum braket set. Well when i go to mount the powersteering pump it hits the fuel pump. My fuel pump off ny 46o comes off the engine then 90 degrees up. I was wondering if any 460 fuel pump would work. Cause i know all the blocks are the same. Cause i think if i get a fuel pump for a 71 lincoln the pump comes out then 90 degrees strait down. If this pump will work on my 79 i could get power steering. Any help would be greatfull. Thanks
Old Jun 28, 2013 | 08:31 AM
wotan's Avatar
wotan
I dont know the answer to your question, but you could block off your fuel pump and go to an electric one.
Old Jun 28, 2013 | 09:37 AM
co425's Avatar
co425
You need to get a 460 saginaw pump bracket from an econoline van. See pics in my thread below. There are a few pics with the bracket in it on the last page.
460 FORD MAN's Avatar
460 FORD MAN
Where do you have the pump mounted?
I have a Saginaw pump and it's at the top right of the motor.
Old Jun 28, 2013 | 12:33 PM
thornton1979
I cant find any saginaw pump brackets for a van. And i have my powersteering pump mounted on top drivers side above the the fuel pump. The fuel pump is in my way.
68Ranger390
Jun 10, 2011 10:52 AM
fslay
Oct 28, 2010 03:08 PM
bigbadwolfe
Apr 1, 2008 08:27 PM
robindanner
Dec 13, 2007 12:32 PM
classyfish
May 18, 2002 12:45 PM
