soft brakes
Old Apr 28, 2008 | 04:35 PM
wmiller's Avatar
wmiller
soft brakes
My brakes have felt soft for a while and feels like the rear aren't grabbing. I've adjusted several times no luck. If I pump the brakes a little they seem to grab much better. Could there be an air leak? Where should i look first. The resivoure hasn't droped any
Old Apr 28, 2008 | 04:51 PM
Cuda_jim's Avatar
Cuda_jim
I would guess the master cylinder has gone bad if you are sure you are not loosing fluid.
Old Apr 28, 2008 | 07:52 PM
wmiller's Avatar
wmiller
any easy way to test?
Old Apr 29, 2008 | 04:33 AM
Cuda_jim's Avatar
Cuda_jim
I would start by disassembling and inspecting the rear brakes. Look for fluid leaks and/or brake hardware damage. A leaking axle seal can cause your symptoms too. BTW: I'm assuming you have drum brakes in the rear?
Old Apr 29, 2008 | 12:00 PM
wmiller's Avatar
wmiller
you assumed right i have drums and there are no apparent leaks anywhere around the brake assembely
Old Apr 29, 2008 | 03:38 PM
Cuda_jim's Avatar
Cuda_jim
If you have a leaking axle seal...may not show up for a while. You might smell it though...nasty diff fluid. If there are no leaks and no damaged brake hardware then the master cyl is probably bad.
Old Apr 29, 2008 | 06:55 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
I would also say master cylinder if theres no leaks.
Old Apr 29, 2008 | 07:08 PM
c00nhunterjoe's Avatar
c00nhunterjoe
do your drums have the nasty rust ridge? if so that could cause the problem. after you pump them will the pedal bleed down quickly? my money is on the rear brakes first since you live in the same salty area i do. if need be i can give you a hand checking it out.
Old Apr 30, 2008 | 11:53 AM
wmiller's Avatar
wmiller
the drums are about a month old so no problem there. The old ones had crack around the outside edge. After pumping the pedle bleeds down but not real fast maybe 10-15sec
Old Apr 30, 2008 | 12:50 PM
tjbeggs's Avatar
tjbeggs
The bleed down is common Its the vacuum booster. There is a no bleed down booster out if you want to fix that. But if the pedal truely is soft it could be MC, air or adjustment.
Old Apr 30, 2008 | 12:58 PM
Neal 97 250's Avatar
Neal 97 250
My bet is master cylinder also. Could be booster.
Old Apr 30, 2008 | 01:39 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
I suppose you also changed the brake pads?, are they the same material as the olds ones?. The problem began with the change of the drums?
DreadyDiggs
Dec 6, 2014 05:11 PM
rpati1978
1997 - 2003 F150
May 7, 2012 05:58 PM
nmichael
Jun 1, 2011 11:25 PM
azpowerstroke
Jul 8, 2009 07:07 PM
dualwheels66
6.4L Power Stroke Diesel
Dec 23, 2008 08:18 AM
