heating issues
Old Apr 28, 2008 | 04:20 PM
PooreBoy's Avatar
PooreBoy
heating issues
I can start and drive my truck but once it gets warmed up and you try to restart it makes a new batery sound dead. Now I have changed everything voltage reg,coil,alt,starter,and installed a mallory ignition along with new plug wires ,plug ext.... Anyone got any Ideas?
Thanx
Old Apr 28, 2008 | 04:50 PM
PooreBoy's Avatar
PooreBoy
Those are new too I thought the same thing.
Old Apr 28, 2008 | 05:55 PM
FE406's Avatar
FE406
does your truck have headers? if so, excessive heat might be affecting starter.
Old Apr 28, 2008 | 06:53 PM
Hillcrest#9's Avatar
Hillcrest#9
PooreBoy ** Your problem has nothing to do with having headers, You have a tipical ford ground problem. A quick,easy and long term fix is to run a second cable the same size as the battery ground cable from the engine block where your battery ground is over to the truck frame. I did this 10 years ago because of the very same problem and never had another starting issue since even with the truck sitting for almost 2 years it still has no starting issues.
Old Apr 28, 2008 | 08:20 PM
PooreBoy's Avatar
PooreBoy
I have changed every thing,Battery,cables,ALT,voltage reg,ignition box,startewr coil,silniod,plug wires distribuator,cap plugs EXT.....
Old Apr 28, 2008 | 08:24 PM
PooreBoy's Avatar
PooreBoy
No it does not,but I was thinking about that and I thought it will warm in 10min and then not start,could it heat the starter that fast,that it may need a heat shield?
Old Apr 28, 2008 | 08:27 PM
PooreBoy's Avatar
PooreBoy
I have done a second ground ,but I went to the fender.
Old Apr 28, 2008 | 10:42 PM
65f100_352's Avatar
65f100_352
Also check your timing.
Old Apr 29, 2008 | 05:52 AM
duste's Avatar
duste
After changing everything the only thing left is engine timming. Get her hot a try bumping the dizzy back a couple degrees at a time to see if it turns over easier.
Old Apr 29, 2008 | 10:45 AM
Hillcrest#9
PooreBoy ** There was a reason why I said to run that second ground to the frame. If I thought for a moment that running the second ground to a fender would work then I would have told you that. Remove the bolt from the block that the battery ground goes to, Clean the block there with sandpaper and also the battery ground end the the bolt goes thru then sand a spot clean on the frame ( there are holes in the frame ) somewhere behind the front bumper, Now on the block useing that bolt attach both cables to the block and with another bolt ( a clean one ) bolt the other end to that clean spot on the frame. I do not run headers but my exhaust pipe is 1/4" from my starter and I have no heat shield and no starting issues.
Old Apr 30, 2008 | 09:41 AM
PooreBoy's Avatar
PooreBoy
I will do that today,I had another person tell me that the starter is getting hot,so i'm going to take that up and get it tested.
Old Apr 30, 2008 | 03:06 PM
montana_highboy's Avatar
montana_highboy
Sounds as though your initial timing may be too far advanced, are you experiencing any starter kickback? it will be harder to start when the engine's hot, try retarding the timing a degree or two.
Old Apr 30, 2008 | 06:30 PM
PooreBoy's Avatar
PooreBoy
High boy,just wanted to say thanx man the ground thing did the trick Thanx
Old Apr 30, 2008 | 07:21 PM
PooreBoy's Avatar
PooreBoy
Thanx man that worked thanx!
weldworks54
Dec 12, 2011 11:48 AM
Boss_hoss
Modular V10 (6.8l)
Mar 4, 2010 05:57 PM
oldwo
Aug 20, 2007 09:26 AM
jwelch
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Mar 7, 2007 11:03 AM
RangerBlues
Electrical Systems/Wiring
Dec 14, 2006 10:15 AM
