General Automotive Discussion
87 Mazda B2200
Old Apr 27, 2008 | 08:45 PM
kjg26's Avatar
kjg26
87 Mazda B2200
A friend of mine has a 87 Mazda B2200. It does not blow heat when the heat is selected, just blows "outside temp" air. also... lately she said it's been indicating that it's overhearing, the truck, other than the sensor, runs fine and does NOT overheat. are these two problems related? Steps to fix hem?
Old Apr 27, 2008 | 09:20 PM
Ford_Six's Avatar
Ford_Six
Check the heater valve, it's cable operated and the cable can break leaving it stuck on or off.
Easily operated manually.
Old Apr 27, 2008 | 09:23 PM
kjg26's Avatar
kjg26
... any clue where a heater valve on an 87 mazda 2200 would be located? any idea on the "overheating" i was thinking bad sensor.
Old Apr 27, 2008 | 09:53 PM
khadma's Avatar
khadma
Carpenter Local 745
Is it actually overheating or running hot? My truck gets to the top line on the gauge, I suspect that the thermostat on my truck needs replacing.
(It opens at a hotter temp now).
Old Apr 27, 2008 | 10:17 PM
ghunt's Avatar
ghunt
What about a plugged heater core?
Old Apr 27, 2008 | 10:36 PM
kjg26's Avatar
kjg26
i do not think it is overheating, no physical signs, other than the gauge indicate overheating. and it's highly inconsistant. sometimes it will be while cruising on highway, other will be while sitting in traffic in town. Sometimes the gauge indicated right between hot and cold, others it indicates HOTHOTHOT. in case ya'lls gauge doesn't have HOTHOTHOT on it, it's slightly above the H.
Old Apr 28, 2008 | 07:16 AM
fellro86's Avatar
fellro86
Best thing to do would be to put an aftermarket gauge on to test to see if it truly is getting hot like that. It could be as mentioned, a sticking thermostat. It could also be a faulty sender... As to the heater valve, it should be in one of the heater hoses.
montana_highboy
Apr 17, 2011 09:45 PM
Secret Agent 069
British Columbia
May 9, 2008 10:14 AM
willis_ainsworth
1983 - 2012 Ranger & B-Series
Apr 14, 2006 01:07 PM
emory1
Engine Swaps
Jan 2, 2005 07:59 AM
74crwcb429hibPS4spd
Sep 28, 2004 12:09 PM
