87 mazda V8 swap
Old Apr 14, 2006 | 12:42 AM
willis_ainsworth's Avatar
willis_ainsworth
87 mazda V8 swap
I have a 87 mazda b2200. I have a 305 i want to put in. How hard is it to put in the motor mounts and does the firewall and fender walls need to be cut? What other problems should I run into?
Old Apr 14, 2006 | 05:42 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Apr 14, 2006 | 12:29 PM
fordboy_52's Avatar
fordboy_52
ur gonna have lots of troubles. electrical is where your going to run into the most problems. you can make the engine a carb motor but its still going to be a bear
Matt
Old Apr 14, 2006 | 12:46 PM
RangerPilot's Avatar
RangerPilot
Yeah...302 swap is easy. 305 would obviously be different though. Just start measuring. See where it will (and won't) fit. Modify as necessary. You'll have to procure some mounts, the computer to run the 305, a suitable transmission, new radiator, may have to relocate the oil filter, stuff like that.
Putting in motor mounts are fairly easy if you have them. You'll have to measure the firewall and fenders to see if anything needs to be cut or beaten into shape. You'll probably have to notch the heater box as well.
RP
Zach
Old Apr 14, 2006 | 01:07 PM
john112deere's Avatar
john112deere
Originally Posted by RangerPilot
302 swap is easy
302 is an easy swap into the Ranger, and the Mazdas that are Ranger clones. That didn't start until '93, though, so I don't think it's that easy for an '87 Mazda.
Hallskee000
Sep 11, 2014 08:32 AM
Terry Webb
Electrical Systems/Wiring
Jun 14, 2014 07:05 AM
irishguyincc
Aug 19, 2005 05:02 PM
bubbaredneck
15
Feb 13, 2002 07:57 PM
