Sponsored by: Real Truck
wont turnover
Old Apr 26, 2008 | 10:04 AM
chadm1978's Avatar
chadm1978
Angry wont turnover
hi I have an 02 7.3 PSD. Last night I tried to start my truck and about half way into turning over it just quit. I waited and tried again but got no cranking sound at all. I figured it was the batteries so I went and got two new ones. Still no cranking. lights come on and everything else sounds like it kicks in just no cranking sound when I turn the ignition.I replaced my starter relay solenoid last week because I was told it needed to be replaced by the guy I bought it from a couple months ago. He also said he replaced the starter not long ago. It was pretty cold where he lives and I dont think he was waiting long enough for the glowplugs to warm up. Anyways I am stuck so if anyone has advice that would be great. oh yeah I think I also have a leak around my high pressure oil pump to top things off! thanks.
02 F350 7.3 PSD
Banks exhaust
K/N air intake
Pro comp susp.
Old Apr 26, 2008 | 11:18 AM
ReAX's Avatar
ReAX
Do you have remote start? The starter wire under the column is interrupted for the brain box, and if it has a blown fuse it will not allow the starter signal to get to the solenoid.
There are also starter interrupt anti-theft devices. Look at the harnesses under the column, see if anyone has tapped anything into it. Other wise check your fuses and contacts.
Old Jun 19, 2008 | 12:02 AM
BioBurner's Avatar
BioBurner
My 02 PSD CC SB 4x4 just did a similar thing! We were at the ice cream shop for some cones for the kiddies, and when my sweetheart went to start the truck, it went through the normal checklist (all of the lights on the instrument panel came on and one by one went out), and when she turned the key.... nothing.
She tried a couple more times with identical results, then... VROOM!
She drove the truck home, parked it in the driveway, and left it there. A few hours later I tried to start it and .... nothing.
Where do I look first (I have already looked and there are no security cut off devices)? I'm very familiar with GM diesel, but this one is new to me.
Old Jun 19, 2008 | 12:08 AM
aldridgec's Avatar
aldridgec
Start at the starter and check for power to the solenoid when the key is turned to start. If it's there, then you have an issue with the starter assembly. Work your way back from there checking components as you go. Even though I own one, I'd have to look to tell you exactly where to look for the next component. Do these have a redundant starter relay/solenoid like some other Fords do? Then check there for both power through the relay and signal from the key switch.
Old Jun 19, 2008 | 12:36 AM
ReAX's Avatar
ReAX
I believe there is a relay before the solenoid.
Old Jun 19, 2008 | 10:05 AM
BioBurner's Avatar
BioBurner
Well, a new twist.
This morning befor I left for work, I decided to try it out. It started right up like normal, multiple times!
Old Jun 20, 2008 | 08:31 AM
BioBurner's Avatar
BioBurner
It did the no crank thing again. I HATE WalMart as it is, but being stuck in the parking lot because your truck wont turn over is even worse!
I got it to work by crawling under the truck and banging on the starter like a caveman.
Old Jun 20, 2008 | 09:57 AM
RACERX7775's Avatar
RACERX7775
well, then you solved your own problem. if it cranked after you clunked on the starter, it probably have a dead spot or two in the starter. cold weather really kills those things. put a starter in it and cross your fingers.
Fordfreak1978
May 14, 2012 10:04 AM
RubberDuck
Apr 2, 2010 06:55 PM
dakzaag
19
Apr 19, 2009 07:47 PM
cjh1925
20
Sep 13, 2007 10:06 PM
ihopemytruckisok
26
Dec 28, 2004 07:08 AM
