Sponsored by: Real Truck
keyless entry keypad
Old Apr 24, 2008 | 12:18 PM
johnf350diesel's Avatar
johnf350diesel
Hi, when i bought my truck it has a keypad on the door. I thought it was stock. ford said it wasnt stock. Does anybody know how to get the code or reset it? I would love to use it.
Old Apr 24, 2008 | 02:04 PM
RDJ184's Avatar
RDJ184
if it was stock i believe the code is written on computer somewhere
Old Apr 24, 2008 | 02:32 PM
Beerstalker's Avatar
Beerstalker
If it is only about a 1/4" thick it is the factory installed keypad. The code will be printed on a card that is usually put in the glovebox, or on a sticker on the keyless entry module behind the dash.
If it is close to 1/2" inch thick it is the Ford stick on keypad. The only way to get the code that I know of is from the card that comes with it (or you can try to figure out which one of the 3125 possible combinations it is by trying them one at a time).
Does the keypad light up when you push a button? If not then the battery is almost dead or it is dead, and you might not be able to try to figure out the code by trying them all. You can pry the front half of the keypad off to replace the battery inside. There may even be a sticker in there with the factory code, but I am not certain of that as I have never had one apart.
Old Apr 24, 2008 | 03:41 PM
mackman's Avatar
mackman
Found the door code on the keyless module behind dash is a little hard to read but is there
Old Apr 24, 2008 | 04:30 PM
Jay Banks's Avatar
Jay Banks
Where did you find the keyless entry module behind the dash?
Old Apr 24, 2008 | 06:46 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
like this one?
Ed
Old Apr 25, 2008 | 10:39 AM
Jay Banks's Avatar
Jay Banks
Ok, Not seeing anything. I looked behind the dash could not locate it.
Old Apr 25, 2008 | 10:54 AM
johnperdeye's Avatar
johnperdeye
where is the key pad modue at exactly i too have this on my truck and have never used it
Old Apr 25, 2008 | 11:50 AM
GregsSD's Avatar
GregsSD
Here is a thread about finding the security module to get the code, one of the posts has some pics to help find it:
https://www.ford-trucks.com/forums/5...locations.html
Restlesswildman
Nov 1, 2016 10:43 AM
Mojos150
2004 - 2008 F150
Mar 24, 2014 08:48 AM
stuart1031
2004 - 2008 F150
Feb 21, 2010 08:26 PM
Greg2561
May 2, 2008 11:54 PM
3KIDDAD
Jan 17, 2007 09:13 PM
