Keypad master password......
Old Oct 24, 2016 | 10:43 PM
Restlesswildman's Avatar
Restlesswildman
Can you change the master password/code for the keypad on the drivers door?
I have a family member that moved out and returned recently and vandalized my engine compartment. The truck is locked and he has no keys to it. So that leaves only one way to get in.
Old Oct 25, 2016 | 01:03 AM
Krazee Matt's Avatar
Krazee Matt
Veteran: Navy
The keypad stores two codes, the master default and owner programmed. As far as I know, the master cannot be changed.
Old Oct 25, 2016 | 04:43 AM
mecdac's Avatar
mecdac
Correct, the Master is the Master and what told me can not be re-set.
Old Oct 25, 2016 | 06:16 AM
projectSHO89's Avatar
projectSHO89
You would probably have to replace the security module. However....
Back in my SHO days, that model's remote security module could be opened up and the internal jumpers could be changed to change the default pass code. I've no idea if that same scheme was carried forward to the Excursion, but it might be an avenue to explore besides swapping the module to get one with a different code.
Old Oct 25, 2016 | 06:35 AM
1 Excursion camper's Avatar
1 Excursion camper
A new or used module is the only way to change the factory code. I never use the factory code, not even sure what it is without looking it up (card is in the owners manual). I did make my own code when I bought it!
Old Oct 25, 2016 | 10:27 AM
robert_l_ross's Avatar
robert_l_ross
No way to know what code was used to get in though.
Changing the user-programmable code is always a good idea:
https://www.ford-trucks.com/forums/1...l#post10496445
...and anyone who doesn't disable that keypad should install an alarm. The instructions I listed above were found directly on the internet with a 2 minute google search. ANYONE can get in within 5 minutes on an older (2000-2001) model. Adding an alarm (in your case with an additional hood lift switch) is advised.
Old Oct 29, 2016 | 08:51 PM
Restlesswildman
I called the local dealer and explained the situation. He confirmed that the module would need to be changed. It is on current eternal back order and is $300, plus 2 hours install and programming at $110 an hr. I found a used one for $100 and still looking at 2 hours install time.
Local kustom shop that does some really cool stuff is also an audio and alarm shop. $350 for an alarm installed. That is probably the way I will go.
Old Oct 31, 2016 | 01:40 PM
Misky6.0's Avatar
Misky6.0
You could also simply disconnect the wires from the keypad...
Old Oct 31, 2016 | 01:52 PM
CharlyG's Avatar
CharlyG
Ford has the master code attached to the VIN number, but they want money to get it for you.
Old Oct 31, 2016 | 02:06 PM
mecdac's Avatar
mecdac
Different dealers different results. Mine was very happy to provide me the number and show me the short cuts.
Old Oct 31, 2016 | 07:09 PM
Misky6.0's Avatar
Misky6.0
Yep, my local FORD dealer happily gave me the master code when I bought the Ex (from another user-car dealer) and took it in for it's first (for me) oil/filter change, and I also bought a new remote for it.
I got a "free" PowerStroke hat too.
Old Nov 1, 2016 | 10:43 AM
RobRoss's Avatar
RobRoss
The code is on the module itself. I believe the module has changed locations slightly over the years but all are behind the dash. My buddy bought an 03 Excursion from a dealer lot and all we did was have someone cycle the locks to help you locate where the module is and then remove whatever you need to get to it. I think on his it was behind the hook. Anyway, I've done this twice and it worked both times. The other time was a taurus wagon.
HTH
THaywood
Sep 12, 2012 06:16 AM
jdhudall
Modular V8 (4.6L, 5.4L)
Mar 15, 2009 09:58 PM
MrMom
2004 - 2008 F150
Mar 9, 2007 04:26 PM
