flywheel
Old Jan 3, 2002 | 05:22 PM
fordzrule's Avatar
fordzrule
flywheel
will a 302 flywheel from a aod work on the fmx. i am putting a 302 in a 60 f100 and i have 2 fmx trannys. and i really dont want to buy another flywheel
Old Jan 3, 2002 | 06:20 PM
serian's Avatar
serian
flywheel
I think it makes more of a difference what year your engine
is than what transmission you put on it. If the flex plate
you are looking to use is the one that originally was bolted
to your engine at the factory, then the only issue you need
to check on is whether the torque converter studs of the FMX
line up with the appropriate holes in the flex plate.
Old Jan 3, 2002 | 08:02 PM
restorit's Avatar
restorit
flywheel
79FordBlake
Jun 10, 2010 05:13 PM
briguyme
15
Aug 3, 2006 08:16 PM
44dwarf
Sep 10, 2002 10:27 AM
mikejen10
Feb 21, 2002 12:35 PM
cigarxtc
Jun 4, 2000 08:06 PM
