will a 302 flywheel from a aod work on the fmx. i am putting a 302 in a 60 f100 and i have 2 fmx trannys. and i really dont want to buy another flywheel
I think it makes more of a difference what year your engine
is than what transmission you put on it. If the flex plate
you are looking to use is the one that originally was bolted
to your engine at the factory, then the only issue you need
to check on is whether the torque converter studs of the FMX
line up with the appropriate holes in the flex plate.
