Is this normal
Old Apr 23, 2008 | 06:27 PM
88 Bronco's Avatar
88 Bronco
Is this normal
Found this under the rear end on a 2003 Ranger I just bought.
Old Apr 23, 2008 | 07:04 PM
88 Bronco's Avatar
88 Bronco
I'm thinking it's not, but I'm not sure. If it isn't normal I'm going to take it back to the dealership.
Old Apr 23, 2008 | 07:17 PM
Bikeitswift's Avatar
Bikeitswift
Does the inside show any signs of undercoating being blown through (as in covering up rust)? Where do you live? Let us know your dealer experience! maybe you bought a Flood Car, plenty were shipped up to "unsuspecting" parts of the country after the floods in New Orleans and Houston!!
Old Apr 23, 2008 | 07:22 PM
88 Bronco's Avatar
88 Bronco
It has rust and shows signs of being mudded, but came clean on carfax. According to carfax this vehicle has spent its whole life in upstate SC. The dealer seemed honest and fixed about three things I found, but it is a used car salesman...
Old Apr 23, 2008 | 07:30 PM
wendell borror's Avatar
wendell borror
It looks like a hole that was punched through instead of rust, I mean it sorta looks ripped.
Old Apr 23, 2008 | 07:32 PM
88 Bronco's Avatar
88 Bronco
No leak and it's holding gear oil.
Old Apr 23, 2008 | 07:39 PM
wendell borror
I would for sure ask a ford dealer about it, you have me curious now.
Old Apr 24, 2008 | 08:31 AM
tomw's Avatar
tomw
Is the pic looking at the bottom of the differential? I'm lost. If so, it looks to me as if there was contact with concrete, as in going over a barrier and being drug along enough to wear a hole, which was then filled with 'something'.
But, back to the question, no, it is not normal.
tom
Old Apr 24, 2008 | 10:47 AM
Bikeitswift
OK, now I'm confused...You said it was under the seat, then you said it "Wasn't leaking and was holding oil"????
Old Apr 24, 2008 | 06:03 PM
88 Bronco's Avatar
88 Bronco
Yes it's the rear differantial housing. A co-worker picked at it and nothing came off. He said he didn't think it was a big deal, and he advised cleaning it up and filling it with JB weld.
Old Apr 26, 2008 | 03:44 AM
tomw's Avatar
tomw
So, no grease or lube came out. Hmm, sell it. A diff run w/o gear lube is not long for this world... mebbe the next...
tom
Old Apr 26, 2008 | 05:05 AM
Dan Robertson's Avatar
Dan Robertson
I dont quite understand exactly where it is. Maybe if you mark the spot so that it can be easily seen and take another picture from further away so that its exact location could be seen.
Old Apr 26, 2008 | 05:17 AM
moat's Avatar
moat
Maybe just a minor casting flaw in the housing?
Old Apr 26, 2008 | 04:29 PM
88 Bronco's Avatar
88 Bronco
The rear end is holding fluid. None is leaking out Sorry I didn't make that clear. My co-worker said the same thing that it may be just a flaw in the housing casting
propellerhead
15
Apr 25, 2017 12:28 PM
Raleigh1
1978 - 1996 Big Bronco
682
Mar 18, 2016 01:29 PM
MOOSE_MACHINE
Testing.....
Mar 18, 2014 07:03 PM
postoak99
1997 - 2003 F150
Mar 5, 2011 11:05 AM
