tri power question
Old Apr 23, 2008 | 02:11 PM
65steelstallion's Avatar
65steelstallion
tri power question
hi guys, it's me again with another rediculous question. as most of you know by now, i'm building a "dream" from my past. and now i've added an addition to it. as usual there is a "slight" problem this old guy needs help with. i have bought tri-power for the beast and am looking forward to it breathing fire when the time comes. but before that happens, how does, or where does the auto kickdown rod hook up on this manifold? my manifold comes from a 4 speed car. i have a 65 F100 SWB currently in the paint shop. it will be a 390 w a C6 trans hook up with Dana 44 posi trac. hook to the earth with ford 8" steel wheels and lot'sa rubber on the ground
bill in horsepasture
Old Apr 23, 2008 | 02:46 PM
rbaker6336's Avatar
rbaker6336
have never saw or owned a tri-power setup with auto,but would think kickdown would hook to center carb
Old Apr 23, 2008 | 02:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What's the Ford ID (casting) number on the manifold? There's more than one setup.
These Tri-Power setups were factory installed on 1962/63 390 Birds (M-Birds), HiPo Galaxies & Merc's (and others) with (1962/64) 406's and (63/68) 427's.
Also sold at the Ford parts counter.
Old Apr 23, 2008 | 07:14 PM
65steelstallion
No Casting # On Intake The Date Is 1d20. Carbs Are Au Av Au Dats On All 3 Are 142
Old Apr 23, 2008 | 08:53 PM
camperspecial65's Avatar
camperspecial65
Do all three of the carbs have their tags...if so, my recollection is theres a 4 digit code on 1st line and the 2nd line is also 4 characters
The top line should be something like C5AF and the lower line should be very similar to what you posted, just that I THINK theres 4 characters is all.
- cs65
joefordtruckf250
Jan 25, 2026 10:50 PM
HillBillyBuddha
Jun 1, 2014 11:19 PM
puroford
Apr 7, 2012 03:32 PM
heavyd86
Jan 12, 2008 12:54 PM
'77fordtony
May 6, 2005 10:23 PM
