which color wire was the fusible link for power to the cab on?
hey guys, i got a quick question. a while back, i lost all power to anything in the cab of my 1977 ford f-150 and someone on here told me it was the fusible link on the wire coming from the solenoid to the cab and i cut the fusible link off and replaced it with a fuse link from autozone and it all worked again. just recently, i started rebuilding the top end on my 460 that i dropped in there and when i started i disconnected that wire from the fuse link. well now im to the point where im hooking everything back up and i cant remember what wire it hooks to again, does anyone know the color of the wire that had that fusible link on it? if someone has a chilton or something, the wiring diagram should say but i NEED to find out bad. im anxious to see the performance this machine has now. i put completely redone 1969 429 high compression heads and an RV cam with .484 lift and 268 degree duration and a weiand stealth intake manifold on it. thanks guys, tony
Sooper Camper
07-07-2013 06:18 PM
cadunkle
05-24-2010 07:47 PM
Sycostang67
09-20-2009 12:09 PM
LARIAT 85
05-25-2007 10:49 AM
