Removed Steering stops
Old Apr 22, 2008 | 11:11 PM
Dieselguy89's Avatar
Dieselguy89
I removed my steering stops or w.e they are called off my 92 F250, that bolt that stops the wheel from getting too close to the leaf springs
Every time I drive around and want to make a corner I end up having to back up alot and make big wide turns every where due to not turning sharp enough, it was probally a bad idea but I there was no way to adjust it. some one welded the stop nut on the bolt. or was set that way from the factory was. I getting sick of not being able to turn enough.
Anyways if I just watch how much I turn and not to turn the wheel hard over and not have the hubs in when turnin sharp I should be ok Right ? Or am I taking a risk of wrecking my front axel.
Any input would be greatly appreciated
Old Apr 22, 2008 | 11:23 PM
PLC7.3's Avatar
PLC7.3
There could be conflict with the tire rubbing or the universal being beyond normal range of motion.......... not seen this mod done before??
Thus the song......."" Give me 40 acres and I'll turn this Ford around!!!!
And you thought big truck stops were for transports!!!!!!
Old Apr 22, 2008 | 11:28 PM
RCrawler's Avatar
RCrawler
Super cabs have a horrible turning radius. My crewcab seems to turn tighter than my old supercab did. Thats TTB for ya'.
Honestly, I wouldn't cut them off. It only takes a little bit of steering from ok to binding the front axle u joints. Not only do you risk breaking them, you can destroy a ring and pinion, driveline, or a transfer case.
Jason
Old Apr 22, 2008 | 11:34 PM
Dieselguy89
Evan if I drive with my hubs in free and in 2x4 will I still end up breaking my ring and pinion, driveline, or transfer case ?
Thanks for the quick reply
Old Apr 22, 2008 | 11:51 PM
RCrawler's Avatar
RCrawler
No, if the hubs are unlocked you will be fine. Do you use 4wd?
Jason
Old Apr 22, 2008 | 11:56 PM
Dieselguy89
Hardly ever... I manily just drive on the highway and threw town on paved roads, last time I ever used it was during the winter a bit
Old Apr 23, 2008 | 01:47 AM
Dodge/Cummins's Avatar
Dodge/Cummins
Diesel engine's low-end torque and a heavy truck can and will break front axle u-joints if you put them in too much of a bind in 4wd. even with the stops, but obviously worse/easier w/o the stops but if you keep this in mind the few times you use 4wd. you should be OK.
My uncle boke his in his stock Dodge Dana 60 in 4wd. Elk hunting turning around in the snow with stock size tires. He was trying to climb just a little bit of a bank to get enough room with the wheels turned to the stop and POW!
As far as the rubbing goes, my F-350 rubs the 36" tires if I turn too sharp. You get used to it and learn how far you can turn, if you get a little rub you just straighten out a bit. l have heavy-lug mud tires though so I definitely know when I'm rubbing. With less aggressive tires you might not notice.
Bosshogoutlaw
1978 - 1996 Big Bronco
Mar 15, 2014 10:03 PM
Butch(OH)
Jul 6, 2013 11:13 PM
dav3455
Jun 3, 2011 09:48 AM
TGenolcyC66
2004 - 2008 F150
May 31, 2011 08:02 PM
nut1605
Jul 28, 2007 01:10 AM
