C-4 vs C-6
Old Dec 13, 2001 | 05:11 PM
nosvmax's Avatar
nosvmax
C-4 vs C-6
I'm swapping an engine and transmission from a 83 f150 stepside into a 84 f 150 long bed. They both have 302's and I also thought that they both had C-6 transmissions...But when I pulled the shaft out of the 83 stepside I noticed that It was a lot smaller than the one from the 84. Comparing the length of the two shafts, the one out of the 84 was a lot longer and also the tail housing tip was larger. Is one of the trans a C-4? Can anyone tell me the difference of the two?
Thanks
John
Old Dec 13, 2001 | 07:09 PM
Caddy 53's Avatar
Caddy 53
C-4 vs C-6
You may try comparing oil pan gasket shape
Old Dec 13, 2001 | 08:41 PM
nosvmax's Avatar
nosvmax
C-4 vs C-6
CADDY 53, YOU WANT ME TO COMPARE OIL PAN GASKET SHAPE..? THANKS FOR YOUR WORTHLESS INPUT
Old Dec 13, 2001 | 10:26 PM
rocky2's Avatar
rocky2
C-4 vs C-6
The c-6 will have a larger slip yoke than the c-4.Its a stronger heavy duty one too.You may have to get a drive shaft shortened/lenghtened for the swap.I swapped in a c-6 for a dismal 3-speed Od manual on a 1979 150 a few years ago. I had to take it in and get it done.
Old Dec 13, 2001 | 11:17 PM
390fe's Avatar
390fe
C-4 vs C-6
[updated:LAST EDITED ON 14-Dec-01 AT 00:18 AM (EST)]John, the C4 has 11 bolts and is a square pan. The C6 has 14 bolts and has a notch in one corner. Before you publicly display your ignorance again, do a little research. It took me less than two minutes to find this page:
http://members.aol.com/autotran3/fmABpg21.htm
Jason
Old Dec 14, 2001 | 04:31 PM
Caddy 53's Avatar
Caddy 53
C-4 vs C-6
John; I have found this site to be very informative and the people I have commented to or talked with have been very positive.
My comment to your question was in noway a smart answer only a quick way to get an answer. IT's a shame you seem to be -----------
BUT sorry if I insulted your intelligence. You may find you create a condition where people won't talk with you.
SORRY caddy 53
Old Jan 19, 2002 | 06:45 PM
Bull's Avatar
Bull
C-4 vs C-6
I should you thank you for your worthless question. If you don't care to even look under your truck, why would it matter if it is a C6 or C4?
Old Jan 20, 2002 | 10:18 AM
airharley's Avatar
airharley
C-4 vs C-6
Remember young grasshoper. It is easier to catch flies with honey then vinager. Also most answers will make you hmm and ask more questions. You may find that the one person you decide had the Generic Motors sound to it had more knowlegde then you may ever be able to comprehend.
Old Jan 20, 2002 | 03:21 PM
Gates's Avatar
Gates
C-4 vs C-6
56panelford
Apr 23, 2014 08:03 PM
connork
Aug 19, 2013 07:41 AM
xsdave
Feb 4, 2006 08:53 AM
FordPickup460
Oct 14, 2004 12:01 AM
