351w/c6 question
Old Apr 20, 2014 | 08:24 PM
56panelford's Avatar
56panelford
351w/c6 question
I have a 351/c6 from a 83 f150 that I'm planning on using in a 56 pickup,also planning on aftermarket MII crossmember. My question is there a need to modify the transmission cover. I'm in the process of replacing the floor so would do the modification now if need be. Thanking you.
John
Old Apr 20, 2014 | 09:30 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
I have a 351W/C6 powertrain and I had to modify the transmission floor cover to make room for the floor shifter linkage. No mods to the floor of the cab, only the cover plate. With a Lokar shifter, I had to cut out part of the center section and raise it up to clear the shift linkage and shift lever.
Old Apr 22, 2014 | 06:03 PM
56panelford
Joe ,thanks for your response. So I understand that you only had to make room for your shifter but transmission clears the pan?
Old Apr 23, 2014 | 08:20 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Only the cover plate needed to be modified. The cab floor and firewall had adequate clearance to the C6. There is a picture in my gallery of the C6 and Lokar shifter sticking up through the missing cover plate opening.
Old Apr 23, 2014 | 10:14 AM
CharlieLed's Avatar
CharlieLed
I live just down the street from Direct Sheetmetal and I have a good working relationship with them. They fabricate a very nice transmission cover for the 53-56 F100s that has a raised tunnel. I have one on my truck, I can get a pic if you are interested.
Old Apr 23, 2014 | 10:28 AM
old_dan's Avatar
old_dan
I can't say for sure on your 56, but in my 52, I didn't have to change much. I used a 351w and C6 from an 89 F150. I also went with a Lokar shifter. I did have to slightly move the hole in the trans cover for the new shifter. I do have an new trans cover that I bought from Northern Classics. It was original in form, but didn't have any of the holes cut.
Dan
Old Apr 23, 2014 | 06:31 PM
56panelford
The reason I'm asking is because I'm completely replace all of the floor in a pickup cab and the 2 front sections don't fit very well, if I but the 2 halves they fit the rocker panels side to side but the transmission opening is 1 inch too wide so if I modify my trans cover need to know if I need extra height as well. This thread would go hand in hand with the fit of patch panels in the other thread regarding LMC patch panels. These are all manufactured by OVAL made in Tiawan that all the vendors are selling, the parts will work but you have to play with them to fit. Thanks all so far for your replies.
Old Apr 23, 2014 | 07:00 PM
CharlieLed's Avatar
CharlieLed
If you can get me a template of the opening I can get you a custom cover made...
Old Apr 23, 2014 | 08:03 PM
56panelford
I'll keep that in mind Charlie, I'm going to finish up this floor first.
mrfox0246
Jun 13, 2010 04:08 PM
g84t8f1
Jan 8, 2007 10:06 PM
all go no show
Sep 30, 2004 09:24 AM
RapidRuss
31
Apr 20, 2004 08:19 AM
dsc
Mar 14, 2002 06:22 PM
