tranny
Old Apr 22, 2008 | 10:22 AM
speedracer54729's Avatar
speedracer54729
tranny
i found a heavy duty tranny trans case combo cheep its from a 6.9 will. Can i makeit mate up to a 351w?
Old Apr 22, 2008 | 10:43 AM
ri_truck_guy's Avatar
ri_truck_guy
The small block bolt pattern will be different. I would see if the size and splines on the tranny input shaft will work with existing clutch and bellhousing. If yes. you just need to worry about bolting the tranny wings to the bell housing, rear tranny mount, and driveshaft size. If the input shaft is different. then see if the heavy duty clutch assembly will fit in the small block bell housing.
Old Apr 22, 2008 | 10:52 AM
Redneck1465's Avatar
Redneck1465
What kind of Trans is it?? If it is a ZF trans there is no chance what so ever. If its a different type like a T18 you can change the bellhousing but it still might not match up.
23
Sep 30, 2010 09:20 PM
KaeJay
Sep 9, 2007 08:02 AM
badass017700
Modular V8 (4.6L, 5.4L)
Feb 27, 2005 02:23 PM
Sunfire_Stomper
Nov 5, 2002 03:31 PM
Jan 28, 2000 06:08 PM
