??? Is my float stuck ???
Old Apr 21, 2008 | 04:37 AM
billb2000's Avatar
billb2000
Hello guys ,I have the ole flathead v-8 with a chandler groves carb on it ,and I was driving it yesterday ,and all of a sudden it started to act like it was looseing power ,and I could smell gas ,there isnt any leaking ,but a strong smell,could the float be stuck,is there a easy way to check and see if it is??
thanks guys Bill
Old Apr 21, 2008 | 06:05 AM
cool 48's Avatar
cool 48
Bill, the first thing I would do , is to pull a spark plug and check to see if it is wet with fuel. If so, I would suspect you r float is stuck. That carb shouldn't be too hard to pull off and bench test. You probably have a small piece of crud stuck in the needle seat . Once you pull the carb, just remove the pin holding the float,and take the needle out. I bet you will find something in there. Hope that helps. If you want to just check it without removing the carb top. Just set it on a table ( level,and find a way to pour fuel into the inlet side of the carb. Make sure the outlet side is draining into a can or something. Once the carb chamber is full of fuel the needle should close and no fuel should come out of the outlet side. If this does not happen, then you can pull the carb top. Hope this helps.
Old Apr 21, 2008 | 07:45 PM
billb2000's Avatar
billb2000
Thanks cool 48 for your help,I will give that a try this week! Bill B
sillyjt
Nov 8, 2011 05:33 PM
fomocojake1
Feb 6, 2009 06:12 PM
THE THING
Nov 30, 2006 03:30 PM
rmalottwtes30
Jan 13, 2006 10:27 PM
1970f2504x4
35
Dec 25, 2003 10:14 PM
