General Automotive Discussion
Help please
Old Apr 21, 2008 | 12:02 PM
fordboy_52's Avatar
fordboy_52
when i said take it apart, i ment axels out too. Fluid can hide in the axels.
Matt
Old Apr 21, 2008 | 08:14 PM
MuddyAxles's Avatar
MuddyAxles
I would also consider a barrier around the pond....or a different address.
Old Apr 21, 2008 | 09:00 PM
lwfox002's Avatar
lwfox002
Matt
I did. No water but at least now I know that. Also, the tranny had no water. Wow did the motor though. Drained it, poured some cheap oil through to ensure all was out of the pan. Plan to change oil again VERY soon after I get it running again.
Old Apr 22, 2008 | 07:09 AM
cjben's Avatar
cjben
not sure if you know this or not,but you should pull the spark plugs and turn the engine over with the plugs out in case there is water in the cylinders. water does not compress,and when the piston comes up on the compression stroke with the valves closed,you will not like the resulting rod knock or rod through the block because that is what usually gives when water is in the cylinder and an engine is started!!
Oh,and maybe teach your daughter to set the e-brake and leave the car in gear before she parks on a hill next time
Old Apr 22, 2008 | 12:58 PM
lwfox002's Avatar
lwfox002
Plugs pulled and motor turned over several different times. She set the e brake, just like my wife, just a little. No real stopping power if you don't engage it firmly. I think she left in in 3rd or fourth. She's learned a leason now.
Old Apr 22, 2008 | 01:43 PM
Lead Head's Avatar
Lead Head
3/4th would do it, very easy for the wheels to turn the motor.
Old May 7, 2008 | 02:19 PM
lwfox002's Avatar
lwfox002
Well, after following everyones advice plus the advice of my mechanic, we got the car on the road again. Everything seems fine. Long term I expect some electrical corrosion problems. We will see. Finances do not allow replacing it at this time.
Thanks all for you help. Another Ford still on the road.
Oh, and we nicknamed it Frog since it is green and came out of the pond.
Old May 7, 2008 | 03:26 PM
SuperSnake's Avatar
SuperSnake
Glad to hear you got the Mustang back on the road for your daughter.
Old May 10, 2008 | 12:03 AM
rebocardo's Avatar
rebocardo
I would not worry about it. For what happened to it, I doubt you will have any problems. Most connectors in modern cars are pretty well sealed and the wire is higher quality AND it was not under water that long. The radio and speakers are probably the things to worry about, if at all.
Old May 10, 2008 | 09:43 AM
jimdandy's Avatar
jimdandy
I have refurbed several vehicles from Katrina. Unless the vehicle was underwater for a long period of time, the trans/rear end will be clear, as you found out. Engine fills up quickly.
Fuse boxes, etc., I would blow out with air. WD-40 is good for getting water out of electrical connections. That is what the WD stands for.
The under dash stuff may cause a problem later on. I would have used an electrical heater under the dash and let it blow for a day or so.
Unpainted metal will rust.
The pond is probably fresh water, so problems down the road won't be as severe as if it were salt water. Salt water never stops corroding in places where you can't get it all out, and even then......... experience speaks. jd
Old May 10, 2008 | 11:31 AM
lwfox002's Avatar
lwfox002
Most underdash stuff was removed and dried, or dried in place. Gage cluster, computers, etc all removed, disassembled, cleaned and dried. Didn't think about the electric heater but I did place a fan blowing under the dash to keep air circulating well. So far so good, we'll see on down the road.
Old May 17, 2008 | 07:25 PM
boatmoter's Avatar
boatmoter
when I worked for ford,anytime a car is under the water you are just looking at BIG problems down the road,the wiring harness and connectors and terminals are going to corroad some,when that happens the resistance will start dropping on computor related componants and the car will continulously quit running,trans will quit shifting properly,abs,restraints & air bags, it will cost bundles to keep that car going.. unless you plan on replacing the complete wiring harnesses and pcm and all modules. this is the reason insurance companys total them out when car has been underwater.. the cars that went underwater in louisiana ended up in FL. and lots of other states to be sold as used cars,we had to run vin #'s to avoid ending up with one of those..
Old May 21, 2008 | 07:20 AM
  #28
MuddyAxles's Avatar
MuddyAxles
This isn't the same, but might help
I am a slob. I have spilled coffee on calculators causing then to go haywire. I've heard of others who have done the same with computers. For what it's worth, I unplugged my calc., cleaned it best as I could, and dried it, best as I could, then didn't use it for a week, leaving it open and in a place where it could continue to self dry.
Outside of some sticky (cream & sugar) buttons, which finally cleared up, the calculator was fine, the computers were fine. I think the key is to do exactly as you have and do not be in a rush, something the professionals don't have time for.
Good luck and keep us posted.
Old May 21, 2008 | 07:54 AM
  #29
boatmoter's Avatar
boatmoter
the repair will come out to be more than the cost of replacing the car,thats why the insurance co. always totals the car,quality work takes time,time is money...but if someone is good enough they can replace their own wiring harnesses and pcm and modules,however,if their going to cut corners,than their wasting their money and time,if it was my car,my time is important to me and not cheap,so I would replace the car..
Old May 21, 2008 | 08:25 AM
  #30
freirefishing's Avatar
freirefishing
Interior is out. Battery was diconnect within 20 minutes of it enteriing water. It was only in less than 20 minutes. My son had to do in and hook a cable to it. Someone with a jeep with winch stopped and helped. Thanks everyone for the help. I will call my insurance agent tomorrow. He is my brother-in-law and handle all our insurance except health. Good guy. We'll see what he can do.
if i were your brother in law and an insurance agent, id add comp and collision to your policy, "do an inspection", tell you to wait a week then file a claim.
