97 Ranger won't idle code P0102
Old Apr 19, 2008 | 04:34 PM
solar2012's Avatar
solar2012
Question 97 Ranger won't idle code P0102
Hi folks...
I have a 97 Ranger won't idle code P0102. Replaced MAF, no difference.
If I drive for awhile by gooseing the pedal, it will settle down and drive OK.
But if you shut it off you go thru the same ordeal.
Now I checked the VOLTAGE at the MAF connector and have only
about 15 millivolts reading.
Is it possible the PCM is shot? Seeing how the sensor connects directly
to the PCM.
Thanks for any leads you may provide!
- Joe (solar2012)
Old Apr 19, 2008 | 04:47 PM
jmgrif's Avatar
jmgrif
Did you reset PCM? The advise here is to leave the neg. battery terminal off for as much as 20 minutes? I'm not sure if this will correct the behavior but it won't cost you a penny! After restarting you will have to drive around a little in order for the PCM to retrain itself!
Old Mar 20, 2015 | 08:06 PM
josephlessey's Avatar
josephlessey
97 ranger
in reference to 97 ranger won't idle did you find problem if so what did you find out please answer me at jlessey1@att.net thanks j. lessey
Old Mar 21, 2015 | 10:14 AM
pawpaw's Avatar
pawpaw
Welcome to FTE
This is a soon to be 8 year old thread, so if you don't get an answer from solar2012 who only has one post & never closed out his thread, go to the top left of the Forum thread index page here EDIT: https://www.ford-trucks.com/forums/forum35/ & click on "Start New Thread" to open a new thread, so you get answers just for your problem.
tmathers03
Jun 30, 2017 09:10 AM
blueline970
Feb 19, 2016 12:12 PM
tallahassee bronco
1978 - 1996 Big Bronco
May 25, 2012 04:37 PM
BOBB13Bs
Jul 28, 2011 04:19 PM
AndeyHall
Jul 6, 2011 09:32 AM
