High pitch rear squeal at low speeds...2003 Explorer. I have replace the front hubs and rear left side hubs. Recently, replaced the right rear wheel bearing, squealing noise is still there. Any advice?
Thanks Steve: However, upon further investigation the noise appears to be coming from the front right wheel; hub assembly was changed about two months ago. What baffles me is why would the replacement of the right wheel bearing now cause the front right wheel noise?
