Mallory Distributor Install
Old 04-19-2008, 09:53 AM
drmgoat's Avatar
drmgoat
drmgoat is offline
I'm installing a Mallory Unilite Electronic Ignition with Vac/advance into a 460 that I rebuilt over the winter. I've got the engine at TDC and go to install the distributor when it dawns on me that I don't know where the plug wires go on the distributor. This motor didn't have a distributor on it as reference and my rebuild manual isn't much help either. Is there an easy way or reference I can use to tell me which plug wire goes where on this distributor?
Old 04-19-2008, 02:50 PM
Bear 45/70's Avatar
Bear 45/70
Bear 45/70 is offline
Doesn't matter as long as you start with the post the rotor is pointing at once you have the dist installed. Then just follow the firing order for the rest.
Old 04-19-2008, 03:39 PM
drmgoat's Avatar
drmgoat
drmgoat is offline
Thanks! That should make this much easier. Just to be clear though. The post the rotor is pointing at will be #1 and from there I go around clockwise in firing order of #1, #5, #4,#2,#6,#3,#7,#8. Is that correct? I know this is simple but this is the first time I've done a ground up build like this.
Old 04-20-2008, 10:18 AM
mark a.'s Avatar
mark a.
mark a. is offline
Counter clockwise.
Old 04-20-2008, 03:08 PM
drmgoat's Avatar
drmgoat
drmgoat is offline
Thanks for the help!
brian1080
05-22-2014 09:30 PM
salf100
15
09-03-2011 12:10 AM
btacarlton
28
04-17-2009 09:40 AM
Abroadwa
03-10-2003 07:20 PM
Quick Reply: Mallory Distributor Install
