ebpv brake
Old Apr 19, 2008 | 12:37 AM
spazinweasel's Avatar
spazinweasel
ebpv brake
can i hook it up so it turns on when the idle switch is active? i also plan on having a toggle to deactivate it when needed. will this cause problems? any help woud be great thanks
Old Apr 19, 2008 | 01:34 PM
powerstrokeddiesel's Avatar
powerstrokeddiesel
x2 i am wondering the same thing...
Old Apr 19, 2008 | 03:01 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i dont see why it cant be done but i would think that it would be impracticle this way. every time the truck goes to idle the valve will be closed, even on start-up and idle
Old Apr 19, 2008 | 04:53 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Sounds like what I'm going to do with my dump truck. Plan on a relay so it disengages the EBPV when the accel is pushed but plan on using the toggle to turn if off when not wanted. Should be the same as the store bought setup, except the cruise override..
Old Apr 19, 2008 | 08:50 PM
spazinweasel
this is what id like to do and have the toggle so i can have it off when not needed. do you think i should use a relay? thanks
Old Apr 20, 2008 | 09:23 AM
79_250RangerLariat
If you don't use a relay then you will have to turn the switch off every time you go to accelerate.
Old Apr 20, 2008 | 11:58 AM
spazinweasel
got an idea on wiring? or a scematic you can share?
Old Apr 20, 2008 | 12:34 PM
Cuda_jim's Avatar
Cuda_jim
The IVS is normally open (no voltage)at idle. When the throttle is pushed It supplies a voltage to the PCM indicating off Idle. The Red w/orange stripe wire goes to the PCM. The brown wire should have voltage all the time. Not sure how much voltage is on that wire though but it looks like 12v...
Old Apr 20, 2008 | 12:39 PM
spazinweasel
super ill give that a shot thanks
Melnickta
May 18, 2015 04:39 PM
johnkn
2015 + Expedition & Navigator
May 21, 2014 10:29 AM
BstangBill
Oct 3, 2009 02:36 PM
Zinfinity
Mar 22, 2009 04:58 PM
oldblue31
Jan 21, 2006 07:27 PM
