1966 - 1977 Early Broncos
73 bronco carb gaskets
Old Apr 18, 2008 | 05:37 PM
hdfx81's Avatar
hdfx81
Just picked up a completely stock 73 Bronco,been sitting since 98. I rebuilt the carb with a kit that came with it.I need to know what to use for gaskets for carb to spacer and spacer to manifold,should the spacer to manifold have holes in it for vacuum for the pvc valve or is it solid (other than the throttle openings) like the carb to spacer gasket?
Old Apr 18, 2008 | 10:21 PM
RCrawler's Avatar
RCrawler
Should be the same gaskets for both sides of the spacer. There should be a passage from the throttle ports to the PCV port through the spacer.
Jason
Old Apr 19, 2008 | 05:53 AM
hdfx81's Avatar
hdfx81
Thanks, I wasn't sure because all the parts books gave a gasket for carb to spacer but didn't give one for spacer to manifold on the broncos but showed a special order gasket with two holes for the pickups and vans
hooler1
May 16, 2014 11:47 AM
lemasters f100
Jan 20, 2014 10:50 AM
RustyTrustyF150
Oct 7, 2013 09:42 PM
Alz Ryde
Jul 18, 2004 04:20 AM
oft
Apr 19, 2001 02:43 PM
