push rods
Old Apr 17, 2008 | 08:39 PM
reifwj's Avatar
reifwj
push rods
Ok, i have been having valve noise on all my valves. I'm going to step up the size of the rods to try and stop the issue. my question is this, would the 360 and 390 have the same push rod length. In my mind, they would not be the same length because the stroke is different. I've been wrong a lot on this truck, but I'm having a good time doing it. The ones in the truck are brand new, but if all my valves are clicking, I'm thinking maybe it has the wrong length rods. the ones I pulled out of the 390 are the same length as the ones in the 360. Is that correct?
Old Apr 17, 2008 | 09:06 PM
jwtimme's Avatar
jwtimme
360 390 push rods are the same lenth, the lenth of the stroke has nothing to do with the lenth of a push rod. I would buy adjustable rocker arms espesally if you have changed the cam to a bigger one.
Old Apr 18, 2008 | 12:54 AM
Ford_Six's Avatar
Ford_Six
They are nominally the same length, but the valve adjustment is through the pushrods, by using slightly different lengths. If you can find a set of adjustable rockers that don't cost a fortune, grab them and use those instead.
Old Apr 18, 2008 | 05:57 AM
jwtimme's Avatar
jwtimme
jegs has them for 280 bucks a set. but if you decide to use the pushrods I would buy an adjustable push rod too check the lenth befor you buy that way you only order new push rods once.
Old Apr 18, 2008 | 06:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jwtimme
360 390 push rods are the same length.
The 360/390 pushrods are not all the same length.
C4TZ-6565-B .. Pushrod ~ 9.62"
Fits F100/350: 1965/67 352 / 1968 360/390
Fits passenger cars: 1958/67 352 / 1961/68 390 / 1968 428
All before change # L2.
C8AZ-6565-A .. Pushrod ~ 9.59"
Fits F100/350: 1968/76 360/390
Fits passenger cars: 1968/71 390 / 1968/70 428
All change # L8.
There was also .030" U/S .060" U/S / .030" O/S .060" O/S pushrods available.
C8AZ-6565-A is .030" U/S and was used 1958/68 (when required) before that running change took place.
C4TZ-6565-B is .030" O/S and was used 1968/76 (when required).
NOTE: C8AZ-6565-A is a 1968 part number, it replaced: C0AZ-6565-J.
Old Apr 18, 2008 | 08:47 PM
jwtimme's Avatar
jwtimme
I stand corrected I reread some info, I was going off the deck height of the FE block which are the same at 10.17 but the diffrence came in the raio of the rocker arm. Some had 1.73 and other 1.76 accounting for the 3 hundreth diffrence.
But still I would buy the adjustable rocker arms, I just don't like the idea of not being able to adjust if I need too.
Old Apr 24, 2008 | 06:47 PM
baitmaster's Avatar
baitmaster
Some yrs back, I had a few worn pushrods (ball had a flat spot.). Kept track of which ones came out of what hole, and bought the next longer rod for the culprits. Parts store had several dif lengths.I just checked each one with a feeler gauge. After that, everthing was quiet, and drove it for another 60,000m before I decided to pull that motor and rebuild another 390 for it.
74f100sc
15
Feb 23, 2016 11:26 PM
dburgess
16
Oct 10, 2004 08:37 AM
Fat Fendered Ford
Mar 8, 2004 08:37 PM
bamabanshee
Aug 12, 2003 05:30 PM
elsmith
21
May 12, 2002 03:24 PM
