carburetor help
Old Apr 17, 2008 | 01:02 PM
Richharr's Avatar
Richharr
carburetor help
well, things are moving along with the prep of my 351w. I was just going to keep the stock 2 BBL carb until I get the extra cash for EFI, but when I took the carb off to set up engine hoist plate, one of the mounting holes on the carb body was just cracked off. so I need a cheep carb to get it running. JY is out of the question (location=$$$)
any suggestions?
I saw this, $220 shipped
Old Apr 17, 2008 | 02:49 PM
jsutton's Avatar
jsutton
I don't have that exact carb but I do have a 500CFM 4412 Holley on my truck and I love it. It fits perfectly.
Old Apr 17, 2008 | 06:18 PM
Richharr's Avatar
Richharr
what is the difference between these 2, same price and specs. is one better than the other
carb 1
carb 2
Old Apr 17, 2008 | 10:58 PM
Beanscoot's Avatar
Beanscoot
The first one has no provision for a choke, while the second one was designed to have a choke, but it's missing. I wouldn't spend this much money on a carb which will be replaced soon by EFI. How about just buying a stock one from the junkyard or swap meet?
You could also get your carburetor base welded (it's aluminum) or use a longer stud and a distributor hold down to fasten that corner.
Old Apr 18, 2008 | 03:14 PM
Richharr's Avatar
Richharr
Originally Posted by Beanscoot
The first one has no provision for a choke, while the second one was designed to have a choke, but it's missing. I wouldn't spend this muchthat corner.
the JY around here will charge well over a hundred if they hear you say carburetor (NY Prices apply). there are no swap meets in the city (space constriction). the EFI wont come for a while, I have a list for the jeep and it falls under axles and brakes. any other suggestions? I would like to buy something already rebuilt and simple to get running.
Old Apr 18, 2008 | 07:48 PM
fmc400's Avatar
fmc400
MSEE
Grab a junk carb off eBay and spend 50 bucks (kit, chem-dip, misc other stuff) to rebuild it. Done it before!
Old Apr 18, 2008 | 09:53 PM
doug1222556's Avatar
doug1222556
Go to autozone.com and get a stock rebuilt, or buy one of the bunches of them on ebay. Now for the kicker, either one may be a piece of crap. This forum has a classifieds and there are others , and don't forget about Craigs list. com. Don't dismiss the earlier advice about a carb kit, while it's not the simplelest thing you'll ever do, it's not rocket science, and the result may not give you max performance or fuel economy, but it will most likely perform well enough to get you down the road in the interim.
Old Apr 19, 2008 | 01:57 AM
Beanscoot's Avatar
Beanscoot
Well how about "use a longer stud and a distributor hold down to fasten that corner."?
If you don't have a spare distributor hold down, how about just using a mess of washers and the nut on the stud to hold down this corner? The carb will be held pretty securely with the other three studs and nuts so this final corner can be kind of hokey for a temporary fix.
PS A C-note for a junkyard carb seems outrageous.
Old Apr 19, 2008 | 10:24 AM
Richharr's Avatar
Richharr
I'm trying to load up on options here and its working. the JY around here have to pay crazy rent, $1900 for a 1 bedroom apartment, imagine how much a whole lot would cost. I am going to do the distributor hold down thing until I figure something out
Old Apr 19, 2008 | 11:19 AM
fmc400's Avatar
fmc400
MSEE
Why not the eBay idea? Last time I went that route it ran me $10 for a perfect used carburetor (MC2100) and all I had to do was rebuild it.
Rusty_S
34
Jun 22, 2016 02:29 PM
Rusty_S
Jun 22, 2016 07:52 AM
64fordf100292
15
Aug 9, 2007 10:52 AM
pierstar
Oct 14, 2003 11:06 PM
CRJ900
May 8, 2002 12:28 AM
