Sponsored by: Auxito
need help with brakes...
Old Jul 12, 2001 | 11:24 PM
mrsdigg's Avatar
mrsdigg
Hi, I have a 97 f150 4x4. I am trying to change the rear brakes and can't get the drums off (seized). Also there seems to be a cap on there, I don't think the drum will slide off but I don't want to assume it's supposed to come off and hammer on it if it's not. I've tried the heat and oil trick and it didn't work.
Any ideas or suggestions????
Old Jul 12, 2001 | 11:32 PM
whomrig's Avatar
whomrig
Can you describe this cap? I have never seen one yet.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Sep 20, 2001 | 04:31 PM
GqSnow's Avatar
GqSnow
Hey, i just had to replace a piston screw in my rear brakes, it popped off and was scraping, but anyway. I thought mine were seized..until i realized the parking brake was on, pop the parking brake, give it a few tings with a hammer, and pull it straight off, it should work. Also, you don't need to touch the cap, it doesn't look like it would come off too easy anyway.
'97 F-150 4x4 4.2 V6 5spd Manual
Old Sep 20, 2001 | 09:50 PM
Ultramagdan's Avatar
Ultramagdan
Take the 5 lb hammer and take that drum off. I have had to use that more than once and so long as you work around the drum you should be okay.
98 F250LD 4X4
Slotted Rotors
Old Sep 23, 2001 | 07:13 PM
98screamer's Avatar
98screamer
I had to use a hammer to remove mine also. Whack it a few times with a healthy sized ball peen,and they will loosen up easily,,,,98
Old Sep 23, 2001 | 07:21 PM
98screamer's Avatar
98screamer
Marauder2004
23
Oct 29, 2020 04:30 PM
kmacht
May 10, 2020 06:14 PM
superbond
Apr 22, 2011 11:47 AM
CooGAR
Feb 2, 2011 11:03 AM
gary_b
Oct 16, 2006 07:46 AM
