Differential Gear Upgrades
Old Dec 31, 2002 | 01:03 PM
BigMattXXL's Avatar
BigMattXXL
Old Jan 3, 2003 | 01:30 PM
khmorse's Avatar
khmorse
I recently bought a 2001 Exp XLT, w/5.4, 4wd, 3.31 rearend. What axle comes in the rearend of these trucks? And, since I want to add larger wheels (maybe 285/75-16 or 295/75-16's), I am considering having 3.73 gears installed, to keep the same relative gearing. Is it possible to have that done to this axle? Also, from what I read on this site, both of these tires should be able to fit under this truck w/o a lift (at least initially).
Ken
Old Jan 3, 2003 | 03:57 PM
marriedguy1's Avatar
marriedguy1
I believe that the rear end is a Sterling/Ford 9.75" , and the front diff is a reverse rotation 8.8". I also have the 3.31 gears in my Expy and will be changing them out when I lift the Expy, hopefully in 2004.
Old Jan 5, 2003 | 08:46 AM
khmorse's Avatar
khmorse
What company would you get the gears from?
Thanks for your earlier response. There are quite a few companies that sell gears ranging from 3.31's up to 4.56 for these axles.
Ken
2001 Exp XLT
5.4L
4wd
Old Jan 5, 2003 | 08:39 PM
buzzard's Avatar
buzzard
Take a look at these guys:
http://www.drivetraindirect.com/html2/dtdframehome3.html
Old Jan 6, 2003 | 08:04 AM
khmorse's Avatar
khmorse
Question on gearing, tire size, and fuel economy. If I were to put a larger tire on my Expedition, say a 295-75/16 and then change my gears to a 3.73 so that I would have about the same relative gearing as what I started with (3.31), would the fuel exonomy also remain about the same? I know that larger tires would bring slightly more weight.
Ken
2001 Exp XLT
5.4L
4wd
Old Jan 6, 2003 | 09:33 AM
buzzard's Avatar
buzzard
You're going to create more drag, so mileage should decrease.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
