Starting problems.
Old Apr 16, 2008 | 12:35 PM
germanford390custom's Avatar
germanford390custom
Exclamation Starting problems.
Hello everyone, first I'd like to thank everyone for the help they've given me so far. Unfortunately I have another issue to address. I have the 74 Ford F100 Ranger XLT. It has a 390 V-8 and a 2 Barrell Holley Carburetor. For the last few days, it's been getting harder and harder to start, not it won't start at all without starting fluid.
I've replaced the fuel filter and checked the fuel pump. They are both good. So, out of curiosity, I took the top off of the carburetor and noticed there is the right amount of fuel in the float bowl, but when I pump the throttle linkage, no fuel squirts into the barrels. What can be causing this? Is there a cheap and easy way to fix this? Please reply as soon as possible as I need to repair this to get to and from work. I work on an AFB (Yeah, funny as a former Marine).
Thanks for all the assistance.
Old Apr 16, 2008 | 01:35 PM
Mil1ion's Avatar
Mil1ion
Accelerator pump diaphragm could need replacing.
Gasoline should start better than starter fluid.
Try pouring a little ( 2-3 ounces) fresh gasoline down the throat of the carb instead.
Check your plug gap and colour of spark at coil HE terminal as well.
Should be blue not yellow.
Old Apr 16, 2008 | 02:38 PM
rbaker6336's Avatar
rbaker6336
also loosen screw on the squirter and see if you get any gas,I have had these plug up
Old Apr 16, 2008 | 08:35 PM
germanford390custom
I've checked the diaphram and it's good. I replaced the coil about 3 weeks ago and the spark is blue. I tore the carb apart shortly after posting this and cleaned it out. It starts now with little hesitation, now it's just running kind of rough. I think I might need to turn down the fuel/air mixture screws. I KNOW I need to turn down the idle. It's idling at about 1200 RPM.
davidreyy
Sep 30, 2014 04:41 PM
mphurlbert
Feb 26, 2014 04:56 PM
olblue77
Jan 21, 2013 09:44 AM
Ford59galaxie
Jan 17, 2013 12:39 AM
Ki-Adi-Mundi
Feb 20, 2012 10:16 PM
