header clearance 351W
Old Mar 8, 2002 | 07:45 PM
truck35's Avatar
truck35
I have a 67 f100 with a 1975 351w in it. The guy that put the motor in it had to beat the back 2 cylinders on the header down because of clearance problems with the steering box (drivers side). Ive talked with the techlines at dynomax, headman, hooker, and sanderson headers and none of them have an application for my combo. I was also told that a 351w block is wider than a 302 that came stock in the 70-72 f100. any help would be greatly appreciated!
Old Mar 10, 2002 | 07:30 AM
airharley's Avatar
airharley
You can buy the truck headers from Summit. All you need is the size of the exhaust ports. They look similiar to the old cast iron manifolds but have much better flow. Also they point down under the #8 cylinder. Would this help?
Old Mar 11, 2002 | 08:19 AM
slikness's Avatar
slikness
Try Doug Thorley headers, I have them on my '82 351w and the fit is awesome...don't know about your particular application, but check them out
Old Mar 13, 2002 | 10:17 AM
cseay1's Avatar
cseay1
The Summit full-length headers (for 69-79 F100 302 2WD) will fit but it will be very tight -- on the drivers side they will be right against the steering box, and on the passenger side the collector flange will come very close to the block flange. A little dimpling on the tube against the steering box will make things liveable.
Chris Seay
Bealeton, VA
49 F1
68 F100
Old Mar 13, 2002 | 10:59 AM
bjoern's Avatar
bjoern
agthomas2
13
Dec 3, 2010 09:46 PM
geodiggr
Aug 5, 2009 07:49 AM
Busted knuckles
Exhaust Systems
Mar 28, 2004 08:23 PM
Todds79
Nov 14, 2001 05:22 PM
jpb
Apr 11, 2000 02:40 PM
