'78 351M flywheel
Old Dec 16, 2009 | 09:21 PM
1Archerman's Avatar
1Archerman
'78 351M flywheel
I have purchased a 351M from a '78 Bronco that I'm installing in my '73 F-100. When I purchased it, the seller removed the flywheel and shroud to avoid bending it in the back of my truck. Trouble is, the flywheel is weighted on one side, and I have no idea where the weight was when it was on before. How can I determine how to align the flywheel so the engine is balanced?
Old Dec 16, 2009 | 09:32 PM
vtjvt's Avatar
vtjvt
I believe the weight is just to balance the flywheel, I don't think it matters where it is located.
Old Dec 16, 2009 | 10:51 PM
CaptainIPSC's Avatar
CaptainIPSC
If you hold the flywheel up to the crank and look at the bolt holes you'll notice that all the holes will only line up in one position. You can't put it on wrong.
Old Dec 17, 2009 | 11:03 AM
fordtech08's Avatar
fordtech08
I agree with Captain it only bolts on one way
Old Dec 17, 2009 | 12:48 PM
1Archerman's Avatar
1Archerman
Thanks fellas. It was exactly as you said - it will only bolt up one way. So I guess I asked a stupid question before even attempting to bolt it up. Oh well, guess its better to ask a stupid question than not to ask and really screw something up bad! I'm quite good at the screwing things up part...
Old Dec 17, 2009 | 01:08 PM
ell Header's Avatar
ell Header
good advice captain and fordtech sometimes its also a good idea to mark and check each bolt hole for the right position, its a common mistake, you live and learn.
jtapal
May 15, 2016 01:17 AM
DrZoom
16
Sep 16, 2015 02:11 PM
Chris Popanz
Nov 4, 2014 10:46 AM
redstrawbarry
Dec 21, 2006 06:34 AM
RGAZ
20
Feb 3, 2001 08:36 AM
