Sponsored by: Real Truck
early 99 superdutys ?
Old Apr 16, 2008 | 06:05 PM
cvdenson's Avatar
cvdenson
Originally Posted by Stone Mathews
CVDENSON,
Can you tell me more about the suspension changes on March 1st? I have the early 1999, and was wondering what the difference is. (I don't have a late 1999 to compare it to.)
Thanks!!!!
Hey Stone,
I guess suspension was not an accurate description, mainly front end stuff as listed in post #4. My bro in law has a 2001 that I've not compared to yet, but once he completes his transformation on his truck, I'm getting all of the later front end stuff along with his turbo, up pipes, and everthing else that makes the early '99 different from the later models.
Chris
Old Apr 16, 2008 | 07:57 PM
superduty4x4's Avatar
superduty4x4
Originally Posted by milburn
So far i"ve found different u bolts and the bolts on the track bar are different.Maybe in the hub bearings and brakes too but i havn't found a complet list yet.And the local parts guys havn't been real helpfull.
Did you not read the list I posted?
Early 99 has a wicked wheel in it from the factory.
The early99 has 120cc(AB code) injectors and the late99-03 has 140cc(AD code) injectors.
The early99 has 2" intake runners. The late99-03 has 3" intake runners.
The early99 has a 15* swash plate HPOP. The late99-03 has a 17* swash plate HPOP.
The early99 has one glow plug relay. The late99-03 has one glow plug relay and one air intake heater relay side by side. Both relays are on the passenger side valve cover toward the front of the truck.
The early99 has a totally different air filter that is not inter changeable with the late99-03. But you can put the late99 air cleaner assembly in the early99 truck. The only two aftermarket air filters that work on the early99 are the AFE stage 2 and the AIS.
The early99 track rod has smaller mounting bolts than the late99-03.
The early99 has shallower rotors than the late99-03.
The early99 has shorter hub-bearings than the late99-03.
The early99 front axle U bolts are square where they go over the spring pack. The late99 U bolts are round.
The early99 has a different pitman arm than the late99-03.
The early99 does not have the AIH like the late99-03.
The early99 does not have the automatic transmission fluid cooler in the radiator.
The early99 has no indicator light showing that "cruise" is on. Late99-03 has a cruise light that will come on when you set the cruise control. The early99 truck has the light in the dash already. A newer PCM(Yes it will plug in and will run better too) must be used to make the cruise light illuminate. It is a green light on the right side edge, half way up.
Everything in bold applies to all Super Duty's, the non-bold stuff is diesel specific.
Old Apr 18, 2008 | 09:35 AM
Stone Mathews's Avatar
Stone Mathews
Chris & Chase, thanks for the information guys. I now know that I have an early '99.
Has anyone put a newer PCM in there early '99? Did anyone notice a difference?
Thanks!!
Stone
Old Apr 18, 2008 | 11:19 AM
cvdenson's Avatar
cvdenson
Hey Stone,
Yes, you can put a newer PCM into an early '99 7.3. Apparently people who've done it says it runs much smoother and a little more power. There is a thread about this very subject and you can read about it here: Early 99 computer upgrade and TS reburn - Ford Powerstroke Diesel Forum.
I'm going to be doing this upgrade as soon as I can. Then I'll have to get my DP reburned and maybe add the 120 and 140.
Chris
brandon_oma#692
15
Jul 4, 2017 12:09 PM
99SuperDuty2017
Oct 15, 2016 09:00 AM
landscapeguy
13
Mar 29, 2016 10:15 AM
Kajtek1
May 10, 2010 03:12 PM
stangclassic66
Dec 1, 2006 09:27 AM
