Yet another early late 99 thread (Chassis cab specific F450)
Looking to order some front end parts. My track bar needs bushings replaced now and I want to have brakes and wheel bearings on hand for when I need them. I would like to order the parts ahead of time and order the correct ones. I had assumed my truck is a late 99 based on the turbo and intake when I bought it. It was definitely not early 99 but i have since switched engines. Now that I have been reading I think I have the early suspension BUT I also read the chassis cabs are different. Here are some pictures:
So can I tell for sure what parts to order?
Track bar or bushings.
Front Brake rotors.
Front wheel bearing assemblies
Thanks for any help.
Trying to link another thread with an attachment.
Data from pdf
Front Brake rotors.
I have a 2/99 build f350 DRW and I want to do a late 99 wheel hub and rotor swap and I came upon this post
https://www.ford-trucks.com/forums/a...2&d=1223841216
The early99 has shallower rotors than the late99-03. (except DRW trucks)
The early99 has shorter hub-bearings than the late99-03. (except DRW trucks)
Since I have a DRW does that mean I already have the late model wheel hubs and rotors? I just wanted some confirmation.
Data from pdf
Originally Posted by pdf data
Here are some differences between EARLY 99 and LATE 99(99.5)
Early 99 has a wicked wheel in it from the factory. And much smaller turbo (spools faster, though)
The early99 has 120cc(AB code) injectors and the late99-03 has 140cc(AD code) injectors.
The early99 has 2" intake runners. The late99-03 has 3" intake runners.
The early99 has a 15* swash plate HPOP. The late99-03 has a 17* swash plate HPOP.
The early99 has one glow plug relay. The late99-03 has one glow plug relay and one air intake heater
relay side by side (along with early '99 CA models) . Both relays are on the passenger side valve cover
toward the front of the truck.
The early99 has a totally different air filter that is not inter changeable with the late99-03 (except for
DRW trucks) . But you can put the late99 air cleaner assembly in the early99 truck. The only three
aftermarket air filters that work on the early99 are the AFE stage 2, the AIS and the KWIKK 6637.
The early99 track rod has smaller mounting bolts than the late99-03. (except for DRW trucks)
The early99 front axle U bolts are square where they go over the spring pack. The late99 U bolts are
round. (except DRW trucks)
The early99 has a different pitman arm than the late99-03. (except DRW trucks)
The early99 does not have the AIH like the late99-03. (except CA model)
The early99 does not have the automatic transmission fluid cooler in the radiator.
The early99 has no indicator light showing that "cruise" is on. Late99-03 has a cruise light that will come
on when you set the cruise control. The early99 truck has the light in the dash already. A newer PCM
(Yes it will plug in and will run better too) must be used to make the cruise light illuminate. It is a green
light on the right side edge, half way up.
Credit to Chase aka superduty4x4, Ron aka Ron's Power Stroke and in Bold credit to Jet
aka SolidGround
If I missed a credit shame on me and I apologize.
aka SolidGround
Sorry I meant to ask does the chassis cab even follow the "date rules"? Some info I found says "except DRW" after most of the suspension differences. What do the DRW trucks have? I guess mine came with the early suspension and late engine?
Thanks. I was having trouble finding pictures since most are 250 and 350. Seems like the chassis cabs followed the same changes.
Any way to tell for sure what hubs and rotors I have? When my brake pads are about done I'll do new pads and rotors and want to match my existing bearings but they may have been changed before I bought it.
Nice tidbit there on the flange thickness to determine early vs late hubs!
Also for the sake of posterity when those pics lose hosting (cough cough oil cooler cough) the Ford part numbers on the track bar brackets read;
F550
F8CA-3A094-AB
F250
YC35-3A094-AC
Somebody rep Cody for me, please.
F550
F8CA-3A094-AB
F250
YC35-3A094-AC
Also would a 4x4 bearing work on the 2wd monobeam axle? Seems like it is the same dimensionally.
I would say the flange with 8 lugs, but on the older 450/550 there are two 8-lug flanges. The flange that needs to be measured is the one containing the 8x170, not the 8x225 (why I said to remove the adapter and caliper/rotor - life can't be too easy).
I don't know about the wheel bearing assembly interchange on the 2wd monobeam though although I'd ASSUME that the only difference would be some kind of plug through the middle. We don't have any 2wd stuff around here for me to dig through.
Yes, the 4wd unit hubs will fit in the 2wd monobeam knuckles but they'll look goofy with a giant hole through the center since there's no shaft going through.
