Sponsored by: Real Truck
Code 1247
Old Apr 13, 2008 | 09:43 AM
madcatter33's Avatar
madcatter33
Code 1247
Does anyone know what code P1247 means on a 5.4 gas engine?
Old Apr 13, 2008 | 10:28 AM
high ho silver's Avatar
high ho silver
Manufacturer Control Fuel Air Metering
Old Apr 13, 2008 | 10:37 AM
madcatter33
what does that mean in english and what do I do to fix that? Thanks
Old Apr 13, 2008 | 04:03 PM
high ho silver
What are your symptoms? Is it searching for idle? Kinda revs up and down on its own while sitting stopped? If so, my guess may be the Idle Air Control (IAC) Valve. They are fairly cheap to purchase and easy enough to do yourself. Some times you can even get by with just removing it and cleaning it. Anyone else have any thoughts?
Old Apr 13, 2008 | 07:50 PM
madcatter33
I guess the symptoms would be loss of power.It just dont have it like it used to.Then when I got the hypertech programmer the code came up.
Old Apr 13, 2008 | 08:02 PM
high ho silver
Hypertech used to put a disclaimer in the instructions that if anything weird happened after using their product to give their techys a call. Have you talked with them yet?
Old Apr 13, 2008 | 08:15 PM
madcatter33
it had lost power before the programmer......and it showed the code the first time I put the programmer on.
Old Apr 13, 2008 | 08:26 PM
high ho silver
Have you ever replaced the fuel filter? If so, try to locate the (tire valve stem) type valve on the passenger side fuel rail and remove the cap. Place a rag over the valve and press gently with something small down in the center. See if you have any fuel pressure release. If not, you may be having fuel pump issues.
Just trying to help with the easy to check stuff first!
Old Apr 13, 2008 | 09:37 PM
madcatter33
yes fuel filter was replaced, I will try the valve in the morning.Thanks
Old Apr 14, 2008 | 09:33 AM
madcatter33
I was listening to it this morning and it does seem like it it searching for an idle.Nothing real noticable but it definiatly does.How do you clean the IAC and whereis it?Thanks alot.
Old Apr 14, 2008 | 08:03 PM
high ho silver
Keep in mind that the IAC's only function is at idle. So if you are experiencing power loss, I doubt it is the issue. However, that said, if it does not idle and hold an idle you can try the cleaning method. It is located at the rear of the intake. It will be mounted with two small bolts. (10mm I think) Each one I have seen has been silver but you can't really see it just standing in front of the truck. You have to crawl up under the hood and reach for it. I'll try to see if I can search for a picture to help explain location.
Old Apr 14, 2008 | 08:17 PM
high ho silver
OK. Here you go. V-10 pix shown but yours wont look any different. And no it is not any easier to get to. Sorry!!!!!
https://www.ford-trucks.com/forums/5...rsion-v10.html
hotrodfeguy
Dec 6, 2016 07:26 PM
COMTNMAN
Aug 23, 2016 10:35 AM
Jared Ajlouny
Aug 11, 2015 07:17 PM
JOHN2001
18
Oct 3, 2013 04:17 PM
madcatter33
Modular V8 (4.6L, 5.4L)
Apr 19, 2008 08:07 PM
