Trouble finding IAC - 2000 Excursion V10
Old Oct 28, 2006 | 11:25 AM
qwertmonkey's Avatar
qwertmonkey
Ok, I've come to the conclusion that my IAC needs to be replaced. The only problem is I can't find it! I'm use to working on european cars, specifically MINIs and BMWs. I'm having a little trouble here! I've take a few pics, so hopefully someone can shed some light my way.
I saw a how-to in someone's gallery, but it looked nothing like the V10.
Here are the pics. If you know where it is, you can either try to explain where it is in the picture, or save it, circle it in red, and the re-upload it.
Thank you!
Old Oct 28, 2006 | 11:35 AM
VHOLT's Avatar
VHOLT
In the 3rd picture that is the IAC. It is right behind the throttle body. It is a pita to get to. First remove the electrical connector, than the bigger black hose is a fuel bypass remove it. be carefull that hose clips to the firewall and the clips will break pretty easy. The IAC is held to the throttle body by 2 bolts I think they are 9 or 10 mm. one on top and one on the bottom. the bottom one you will have to remove blind. I hope that helps VHolt 00x V10
Old Oct 28, 2006 | 11:49 AM
VHOLT's Avatar
VHOLT
Try this link it should help. https://www.ford-trucks.com/user_gal...&albumid=22274
VHolt 00x V10
Old Oct 28, 2006 | 12:01 PM
qwertmonkey
Thanks for the info VHOLT. The link that you sent me, thats the one that I used. It just didn't make sense to me. But now, I know where it is.
Thanks for the help!
Old Oct 28, 2006 | 07:54 PM
caddys83's Avatar
caddys83
The bottom bolt is easier to get to from the driver side. Also becareful as there is a gasket back there.
Old Oct 28, 2006 | 08:02 PM
qwertmonkey
Just to be sure, your saying its the horizontal cylinder shaped thing in the third picture?
Old Oct 29, 2006 | 05:15 PM
caddys83's Avatar
caddys83
Hope ImageShack.US works on this site http://www.imageshack.us/
Old Oct 29, 2006 | 07:41 PM
Monsta's Avatar
Monsta
Sit. Stay.
Hey man, after you change your IAC go dig out your pressure washer and give that thing a bath!
big-ugly
Nebraska Chapter
142
Mar 15, 2017 04:10 PM
twistedfreak
48
Apr 11, 2016 02:14 PM
villestrip
May 3, 2011 02:27 PM
bookpile
Jan 7, 2011 11:06 PM
WhozNxtLS1
New Jersey Chapter
Mar 1, 2007 07:29 PM
