General Automotive Discussion
gas tank
Old Apr 12, 2008 | 09:25 PM
blueovalfan's Avatar
blueovalfan
gas tank
A friend of mine bought a motorcycle , its been sitting for a while. It has rust in the tank , how is the best way to clean it ?
Old Apr 13, 2008 | 06:02 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
How bad's the rust?
1) I cleaned the rust out of the tank of my Beemer by first pouring in some small bluestone (3/8") and shaking it around with a little water for an hour or so to abrade the worst of it.
2) Then I filled it and let it sit with a dilute acid solution to "burn" off any rust that remained.
3) I then rinsed it out with water and finally with MEK to get all the water and keep it from rusting up right away. (be careful of the paint)
4) Bring it to a radiator shop and have them line it with Redcoat. This is less than $30 around here and really works. It will seal the tank and bind any little bits you might have missed.
Old Apr 13, 2008 | 10:09 AM
jimdandy's Avatar
jimdandy
If the rust has been there a while, it may have pin holes if you remove the rust. I use hydrochloric acid(muriatic acid) on rust. I mix about a 5 to 1 ratio for most stuff. I you use the acid, do it outside. The gas from the acid will screw up everything in the garage if you let it sit for any length of time. Experience is sometimes a cruel educator. jd
Old Apr 14, 2008 | 11:56 PM
ford2go's Avatar
ford2go
Just a side note. I don't know much about this subject, but if you use MEK, be careful to not breathe it. That stuff is not good for you!
ford2go
Old Apr 15, 2008 | 05:27 AM
wiseguy's Avatar
wiseguy
Eastwood sells a kit just for that purpose. I used it once on an old bike tank, and it worked fine. It contains everything you need to do the tank except muriatic acid.
Old Apr 15, 2008 | 08:50 AM
ddrumman2004's Avatar
ddrumman2004
Do what is suggested in Jim's post and also have your friend invest in some good inline fuel filters.
timpage
27
Aug 10, 2016 10:53 PM
swampthang
Mar 3, 2014 12:49 PM
bcaughhorn
20
Feb 2, 2011 07:39 PM
PATS2002
Jan 2, 2003 09:06 AM
parr4
Apr 8, 2002 06:17 PM
