Sponsored by: Real Truck
Vibration Problem When Towing
Old Apr 12, 2008 | 06:04 PM
joeskeeter's Avatar
joeskeeter
I have a 2000 F250 SDCC4X4 When towing a trailer I periodically will get a vibration the runs through the whole truck. Only happens when I hit a sharp bump in the road. The sometimes it will quit on its own most time I hit another bump and it stops. Pulling a 21" bassboat w/ tandem axel trailer, surge brakes. Have pulld over and checked all bearings and brakes and NO heat. Did check the rear in in the truck today and it was very warm to the touch. I'm pulling my hair out trying to find this problem. Anyone have a suggestion or further question on the situation?
Thanks
Old Apr 12, 2008 | 06:15 PM
jake00's Avatar
jake00
is it only with that trailer, or does it do it with other trailers as well
Old Apr 12, 2008 | 06:50 PM
joeskeeter's Avatar
joeskeeter
Haven't noticed it with other trailers, but don't pull them very far. It started on the way home last week. Drove 250 miles there no problem 1/2 way back it started. Today went 100 miles no prob. 1/2 way back it started.
Old Apr 13, 2008 | 12:03 AM
mohle's Avatar
mohle
Can't say that it happened on my truck, but a friend of mine had the same issue on his 03. Turned out that it was the driveshaft support bearing.
Old Apr 13, 2008 | 08:24 AM
joeskeeter's Avatar
joeskeeter
After I got off of the highway I checked the carrier bearing and u-joints none were loose at all and all were cold to the touch.
Old Apr 14, 2008 | 08:19 AM
joeskeeter's Avatar
joeskeeter
Bump HELP.
Old Apr 14, 2008 | 08:24 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is this boat the heaviest load you pull, either gross weight or tongue weight?
I would check your tire pressure, maybe even add 5 more pounds of pressure, as a start.
Old Apr 14, 2008 | 09:06 AM
joeskeeter's Avatar
joeskeeter
check tire pressure and all are right at max for the tires. Its almost like theres a switch that turns it on and off. Has to be a sharp hit like a transition on an overpass will start it then sometimes it stops on its own and sometimes I will hit another sharp gap and it will stop. This boat is not the heaviest I pull but it gets pulled 99.5% of the pulling this truck does. How warm should a rear end housing be after pulling for 100 miles?
Aufgeblassen
All Things Towing
21
Jul 14, 2014 05:39 PM
crown180
All Things Towing
Sep 10, 2010 07:19 PM
lasmacgod
Aug 19, 2010 04:40 PM
lt6124x4
Jul 26, 2005 07:39 PM
jeffbk
Dec 29, 2004 03:54 PM
