Sponsored by: Real Truck
Bad Vibration (Challenging)
Old Dec 28, 2004 | 07:01 PM
jeffbk's Avatar
jeffbk
Question Bad Vibration (Challenging)
I have a 99 4x4 Superduty 7.3 with 96k I just replaced the calipers,rotors, pads and anti sway bar supports. I also put 4 Dueller revo a/t s on I now have a vibration/grinding noise under the following conditions:
After I hit a bump- vibration starts hit another bump-vibration stops
Cold weather the grinding/vibration is very strong until it warms up. If I stop the truck the vibration will stop(almost like a release) When I start there will be no vibration until I hit a bump. The vibration occurs whether I am in gear or not, 4x4 or not. At higher speeds (over 40 mph) the vibration is steady.
Should I pull apart the axels and check for bad bearings? Any ideas?-There are so many threads on vibrations but none seem similar to mine.
Thanks
Old Dec 28, 2004 | 08:16 PM
V10MARS's Avatar
V10MARS
Me thinks you may have gotten the wrong brake pads and/or There is missing or damage caliper hardware.
If you still have the old pads around, pop the new ones out and look at them again.
Old Dec 28, 2004 | 09:48 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Thanks
Welcome to the only family Ford Truck site, on the net. The members in these forums are very knowledgeable about trucks; they will eagerly help you…with your question. If you have a minute check out the Guidelines, it will help you to navigate through FTE.
Enjoy FTE
Old Dec 29, 2004 | 03:54 PM
Munkey's Avatar
Munkey
Your vibration sequence looks familiar (vibrates after hitting bump, doesnt stop till another bump hit), I think in the past another member had the same problem. If I remember correctly, it's the wheel bearings. I'm not 100% positive on that though.
I feel your pain on the number of vibration threads, there are TONS!
I'm sure someone will be along to help you shortly!
William Martinez
Feb 23, 2017 11:22 AM
Storm Knight
Jan 10, 2017 09:46 AM
walter white
Oct 29, 2016 07:23 PM
DidieX
Jun 10, 2016 11:07 AM
immaculate
Modular V10 (6.8l)
Dec 18, 2003 08:10 PM
