Alternator problem?
Old Apr 11, 2008 | 11:51 AM
powerstroke02's Avatar
powerstroke02
Alternator problem?
hello to all, have a 02 350 psd and im on my third alt. with 146k miles. first one went at 136k? and replaced and that one was junk only putting out about 12.5v then bought this one which was fine til the last few weeks. most of the time it works fine at 14.2v but sometimes it jumps around, it will sit at 12v for a few minutes then 13v or wherever for a few then back to 14v. its worse at start up and idleing for a few minutes. Just wondering if this one is bad now too or what?! got it and auto value. and if it is bad, where should i get one and where would be the cheapest? i paid $212 for the last one but dont have the money for another one. any help would be great, thanks!
Old Apr 11, 2008 | 12:45 PM
PaysonPSD's Avatar
PaysonPSD
Get it bench tested if you haven't already. If you get another one have it bench tested before you leave the store. Here is an online site which has come recommended by others on this forum High Output Large Case Alternator Upgrade for Ford 7.3l, 6.0 & 6.5 Power Stroke Diesel
Old Apr 11, 2008 | 12:49 PM
robinsonpowerstroke's Avatar
robinsonpowerstroke
Well if you spent that much money on the last one, I would hope that it had some sort of warrenty. Where did you get the last one at? I got a cheap one from Advance Auto and it would jump around like that. Went and returned it for the more expensive one and that one works great now.
Old Apr 11, 2008 | 01:01 PM
PaysonPSD's Avatar
PaysonPSD
Just thought of the chaffing wire problem others have had on the wires of the 2 pin connector on top of alt. One person had to use a magnifying glass to see that insulation had been worn through. Jiggle the wires while watching the alt output voltage.
Old Apr 11, 2008 | 01:02 PM
dryfly's Avatar
dryfly
If after you get it bench tested.And it shows the voltage regulator to be shot,or something else maybe.But thats what it sounds like.I would order a 200 amp alt from these guys.Just got a high torque starter from them.Very pleased with the quick service.And so far the product is superb.http://stores.ebay.com/GRAND-ALTERNATORS-AND-STARTERS.I didnt buy through e-bay.I called them and did it over the phone.Doesnt matter though,wich ever your comfortable with.
Old Apr 11, 2008 | 01:06 PM
powerstroke02
thanks for the help and no i did not get a warranty! My dad picked it up i was working at the time. got both at auto value. this last one was free cuz a brought in the second one the same day after i installed it,i tested it. i dont really need a high output alt. though. i just run subwoofers and my truck is decked out in amber and red lights so stock one should be fine?
Old Apr 11, 2008 | 01:08 PM
PaysonPSD's Avatar
PaysonPSD
Bruce,
That link isn't working. Seems like since the upgrade some links have been iffy. Have had trouble posting links myself. Try to edit in a space or two after that link.
Edit: Worked when i did a copy and paste and back spaced through the I and Period. The I and Period became part of the link.
Old Apr 11, 2008 | 01:09 PM
powerstroke02
bruce that link wont work?? so should i upgrade to the 200 amp. or stick with the 110 amp?
Old Apr 11, 2008 | 01:16 PM
PaysonPSD's Avatar
PaysonPSD
Try it now:
eBay Store - ALTERNATOR STARTER AUTO PARTS: ALTERNATOR, STARTER, ACURA
Then do Store Serach for Powerstroke.
Unless you run a lot of electronics 120 to 140 amp should be sufficient.
Old Apr 11, 2008 | 04:15 PM
dryfly's Avatar
dryfly
Sorry about that.The link that Robin gave you is the same e-bay store.Grand Rebuilders.I had a good experience with them as I said.I like to talk to a person to make sure I'm getting the rite part.
Old Apr 11, 2008 | 10:09 PM
farmdad's Avatar
farmdad
powerstroke02, if you still have the receipt for the alternator, you should be able to get it warranteed. Might have to come up with a date and mileage when installed. It would be worth a try.
ajg617
Oct 1, 2014 08:53 AM
beesareoh
Sep 22, 2013 01:05 PM
bergy 2000
Apr 25, 2012 05:59 PM
rustyoilpan
Nov 17, 2006 01:26 PM
