Tolerance for C6 Forward drum
Old Apr 14, 2008 | 07:58 AM
  #31
HemiEater's Avatar
HemiEater
Originally Posted by stuart1
Some versions did have a wavy in the low/reverse clutch pack.
so would that give me a harsh engagement with out that one installed?
  #32
HemiEater's Avatar
HemiEater
sorry I guess I should have started anothe post....
Old Apr 14, 2008 | 08:06 AM
  #33
stuart1's Avatar
stuart1
If your transmission came with one then it should have been reinstalled.
That is one I always reinstall.
Old Apr 14, 2008 | 08:11 AM
  #34
HemiEater's Avatar
HemiEater
well there you go... guess I had my drums mixed up.... I knew I left them out to get as many clutchs I could in.....
Old Apr 14, 2008 | 08:25 AM
  #35
stuart1's Avatar
stuart1
The low/reverse pack is in the back of the case.
The drum with the band surface is high/reverse.
The other one is forward only.
Old Apr 14, 2008 | 08:48 AM
  #36
l-m tech's Avatar
l-m tech
Yes I build transmissions for a living, since 1964 and retired from it after 40 years.
I am not sure if you are attempting to be nasty or funny with your statement of leaving out parts.
Manufacturers install some parts for customer demand or for something to brag about to increase sales that don't really work that well.
The wavy spring in the forward clutch is one.
There are shift kits used and quite often an item or items are omitted.
Modifications are made to the cooler supply and return.
Holes are drilled to enhance a shift or supply better lubrication to a certain area.
Holes are also drilled in drums to exhaust residual fluid.
As for a harsh engagement allowing too much clearance is one cause.
That's why I never go over .005 clearance per fibre plate in the forward drum.
With a forward 5 fibre drum @.005 per plate gives .025 clearance.
Increase that to .008 and you have .040.
.012 and you are at .060, nearly 1/16".
Clearance in the direct drum can and should be a bit more because of the terrific speed at which the fibre plates are spinning when in first or second.
The extra clearance there helps to prevent partial application or drag due to residual fluid in the drum.
The Ford number of the wavy spring, which was introduced in 1976.
D6AZ-7E085-B
As for slamming into reverse the omitted wavy in the forward drum has diddly squat to do with it.
In reverse the rear and direct clutch are engaged. The forward clutch adds nothing.
are you setting the forward clutch clearance tighter because forward isnt a shifting clutch.dosnt the wave spring help soften the enitial forward engagement.not trying to be dumb,just keeping my mind open to other trans builder thoughts and ideas.closed mind makes you limited to your future.
Old Apr 14, 2008 | 09:17 AM
  #37
stuart1's Avatar
stuart1
__________________
ASE MASTER TECH FORD SENIOR MASTER TECH
Yes, because I feel after while the wavy has a tendency to flatten out to the point it is not wavy anymore.
That produces unwanted extra clearance.
An exchange of ideas is always welcome, that's how stuff gets better.
This is not in referrence to you but many people say stuff like "you dumb SOB, that's not how we did it".
I am always open to suggestions.
40 years of building transmissions has taught me lots.
Old Apr 14, 2008 | 01:05 PM
  #38
Mil1ion's Avatar
Mil1ion
This is from my photo bucket album and has been available for viewing for weeks
Old Apr 14, 2008 | 01:11 PM
  #39
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I don't do too many auto tranny posts unless they pertain to flexplates.
Thanks for posting the pic...now ppl will see where the 7E085's fit.
Hemi-Eater's C6 illustration doesn't show them.
Old Apr 15, 2008 | 12:54 AM
  #40
77f250429's Avatar
77f250429
Well i got it all back together, ended up having room for the wave plate in the forward after all. yeah mine did have the wave plate in the low/reverse pack as well. So i ended up with 4 clutches in the reverse/high and 5 in the reverse/low and forward drum. R servo and FF lever. Everything went back together real easy. Air checked it and seemed fine, no leaks. End play before rebuild was about .030 and after rebuild was at .023. Thanks again everyone and i'll let you know how it works once i get it installed
Old Mar 11, 2011 | 09:01 PM
  #41
roscoe14eb's Avatar
roscoe14eb
does any one know many fiber clutches the forward clutch has i tore down my original 75 c6 and it only had 3 fibers. that doesnt seem right. thnaks roscoe
Old Mar 11, 2011 | 10:40 PM
  #42
HemiEater's Avatar
HemiEater
That's seems right...
earl92
Feb 26, 2015 02:11 PM
Scifi266
Aug 18, 2013 11:03 AM
biscuit141
1997 - 2003 F150
24
Aug 11, 2012 09:26 PM
DRM2004
2004 - 2008 F150
Jul 25, 2009 09:48 PM
