Sponsored by: Real Truck
Brake Pads
Old Apr 10, 2008 | 01:27 PM
loudford's Avatar
loudford
Brake Pads
Hi All,
I'm about to replace my front rotor's & pads on my 03 f250 5.4L w/55K. The rotor's have been turned once by the dealer back with 35K I figure it's time to get rid of them and went with the PowerSlot rotors (not cryo). Now I have a new set of severe duty factory pads that I've been saving, well over the winter my truck box ended up with snow melt inside and the pads were soaked. So the questions is do you think the pads are okay after a good clean up with a wire brush (I think they were over $100 back when I bought them) or go with a new set? I figure they see this exposure while installed so wouldn't be a huge issue...
Thanks
Lou
Old Apr 10, 2008 | 05:13 PM
o4f350joe's Avatar
o4f350joe
Depends if they just got wet they should be ok... but if they were in a box that was full of water and they sat under water for a while you better just chuck em in the trash and fork over the $ for some new ones!
Old Apr 11, 2008 | 08:00 AM
loudford's Avatar
loudford
Thanks for the reply,
I'm not sure how long that sat in water for so I think your right I just need to replace them.
Old Apr 12, 2008 | 07:04 AM
o4f350joe's Avatar
o4f350joe
Sitting under water will change the chemical compound causing cracking under extreme heat or cold.
SkySkiJason
Sep 28, 2015 06:31 PM
BaitGuru
Jan 20, 2015 06:53 PM
smlford
Jun 8, 2012 09:26 PM
UP_There
13
Oct 13, 2008 01:51 PM
Matthew Henson
2004 - 2008 F150
18
Sep 15, 2005 08:43 PM
