My trans guy told me to put in two gauges, one in the line to the cooler and one in the return line. That way you can tell how good your cooler is doing and if it gets clogged.
That chart is valid for older fluids like Type F. Seals don't harden at 260F, either. And I can tell you from personal experience that clutches do not slip at 320F, much less at 295F. Clutches do not burn up and 315F, and modern ATF does NOT form carbon at 315F. That chart is from the 50's or 60's, or it's just a lie to sell bigger coolers.
The maximum sustained trans temp is 221F, with a short term (less than 30 minutes) to 252F allowed.
I've run transmissions above 320F and then torn them down for inspection. There was NO damage to ANYTHING in the transmission, including the ATF. There was no varnish in the trans, either, and according to the chart the trans was 80F above the temp that forms varnish.
According to my guage then yesterday when I was pulling a big load, 30,820# gcvw catching alot of wind. I was still safe becuase the highest it got was 215. but it sayed over 200 for most of the trip. I wasn't trying to set any land speed records just taking it easy.
Ive hesitated putting an additional cooler on becuase most loads it barely brakes 190 and empty it takes a while to get to 160. I don't want to over cool it I imagine that can be just as hard on things.
Maybe we should adhere to the 60's standards, those trannies seemed to last forever, but 60's or not 3-5K is a lot of $$ for a transmission. Telling anyone to run there trans as hot as you are eluding to is irresponsible. I'll keep mine running below 200F...thank you very much!.
I can tell you that I have replaced many e4od's and 4r100's with less than 75K. Some with even less miles. Most were original from Ford. They had just the original cooling in place. I added larger coolers to ALL the remans. They all over 200K more without a failure. Some are still going strong with more than 300K of hard, hard use. (4 place car haulers ect)
When you ran that tranny at 320F...was it yours and you had to foot the bill?....or was that when you were a "Ford automatic transmission engineer"? and Ford paid the bill.
All the coolers I install are oversize but I add a thermostat into the equation. I'm sure there is a minimum temp, ...but with a therm the trannies get up to temp pretty quick and then stay below 200F most the time...even under extreme pulls like you are doing.
Of course that was Ford's transmission. I needed to see the results of running it that hot.
I don't run mine that hot. I keep mine below 221F, though on a steep grade I wouldn't be concerned with anything below 252F, though I've never had mine get that hot.
Where did I tell someone to run their trans hot? I must have missed that.
And I wasn't eluding anything, I'm still right here. I was alluding that the company that spreads that chart around may not be completely honest.
All I did was point out that the chart you posted is not correct. I stand by that. It is NOT correct. It is either outdated or intended to scare people into buying more cooling that does nothing except make the seller richer. Keeping the trans below 200F vs below 221F will not make a measurable difference in it's lifespan.
And all those scare words on what happens at higher temperatures are just plain not true with modern fluids and materials inside the trans.
I am with Jim on this one. It might be ok to run a tranny that hot but Mine is staying below 200 if I have anything to say about it. Mark about what temps do the front seals start puking fluid?
I have been a trans rebuilder for 25 years the number one cause of trans failure is still heat,so I believe in big coolers and synthetic fluid.My 2 cents
OK, OK, I want to know about under temps! I think I've over cooled mine and I don't have a thermostat on my setup. So, what is the minimum temp and what happens if you run your trans to cold?
The fluid is pumped from the torque converter to the cooler then back to the trans to lube the planetary geartrain,so if the fluid gets too cold to flow at the external cooler you have poor lube,got to get really cold for that.
