temp for elec fan switch
Old May 26, 2002 | 03:33 PM
78bronco's Avatar
78bronco
im adding a electric fan to my 351W with no a/c, at what temp should the fan kick on, and when should it go off?
Old May 26, 2002 | 06:36 PM
Franklin2's Avatar
Franklin2
Factory switches are usually around 220-230 degrees. I would keep it at least 10 degrees above your thermostat temp to keep it from running all the time. Most vehicles have a 195 thermostat. You could set the fan to a lower temp if your thermostat was lower.
Old May 28, 2002 | 06:53 AM
78bronco's Avatar
78bronco
i'm going to use a fan from a early 90's mercury tracer. how big of a fuse should i use?
Old May 28, 2002 | 11:01 AM
cajunbronco's Avatar
cajunbronco
dr103
Jan 26, 2012 11:14 PM
cornking
18
Sep 23, 2010 03:13 AM
Tptoe
Dec 16, 2003 03:05 AM
serving_time
Sep 14, 2003 02:53 AM
Ol' Blue
Mar 28, 2001 01:24 PM
