Electric fan temp switch
Old Sep 9, 2003 | 10:14 PM
serving_time's Avatar
serving_time
I am planing to install an electric fan in my truck. If I am using a 180 or a 190 thermostat, what temp should the fan be set to come on at?
Old Sep 10, 2003 | 06:58 AM
jwtaylor's Avatar
jwtaylor
Well the switch I use is supposed to come on at 170, so if you are using an adjustable unit then I would shoot for that or a little less. I used the $20 option that you mount to the radiator hose. It has been there for the past 4 years with no trouble, kicks the fan on when needed. If you want to use your a/c then you need the relay as well it cost about the same, but you probalby knew all this. Again I would shoot for 160-170 I don't think you can kick the fan on too soon the sooner the better, however my truck temp runs right were it should yet the fan doesn't come on that often. This upgrade won't throw your a** back in the seat but it will make your truck seem to perform better or at least it did for me and ever post I have read on this subject says something similar, would definitely do it all over again. Good luck the hardest part will be getting the fan clutch off.
Old Sep 10, 2003 | 05:08 PM
javi2001's Avatar
javi2001
Well it depends...
If switch is installed in head OR calefaction hose, closer to T-stat the best set point is 7 to 9 ºF higher than T-stat opening point.
If switch is located at water pump (Where hose coming from radiator is...), the best set point is same as T-stat opening point.
In my own experience, for T-stat opening at 180ºF and switch located at calefaction hose close to T-stat, 188ºF works very fine.
For T-stat opening at 180ºF and switch located at water pump, 178ºF works very fine.
Note: I don't recomend use 160 T-stat, specially on EFI engines or where ambient temp is lower than 27ºC
Regards;
Old Sep 10, 2003 | 07:52 PM
serving_time
Thanks for the advice. One says a little lower, one says a little higher, but both about the same as the t-stat. Anyways, I will be using a 180 or 190 stat (need the heat in the cab up here ). I don't have a fan clutch. I am running an older engine with a carb, and I have the direct bolt on flex fan. I just need to unbolt it and use smaller bolts to re bolt the water pump pully to the pump. Thanks guys.
Old Sep 11, 2003 | 01:14 PM
SPROCKET's Avatar
SPROCKET
I just installed dual 14" fans in my truck.
I've got a 195F T-stat so the first fan is set to turn on at 200F and the second fan is set at 210F.
These engines run at peak performance at 210-215F.
Old Sep 11, 2003 | 04:09 PM
javi2001's Avatar
javi2001
Upsss! if your are planing remove stock fan and install a electric fan thinks are a bit different:
Install Switch at water pump inlet connection and set up it to 15ºF lower than T-stat. This is the best configuration based on my experience.
There is an optional configuration: install switch at engine block, where is installed gauge temp sender (3/8" NPT), setup it to 5ºF higher than T-stat opening point. This conf. works better than any other.
Regards;
Old Sep 11, 2003 | 04:14 PM
jwtaylor's Avatar
jwtaylor
Like 170*? j/k
Old Sep 12, 2003 | 09:26 AM
SPROCKET's Avatar
SPROCKET
Really makes no sense having them come on before the T-Stat even opens, I personally like it to warm up faster and run better.
Old Sep 12, 2003 | 11:14 AM
jwtaylor's Avatar
jwtaylor
I wrote a big spill on my opinion then deleted it. It is all up to the user, these things run pretty efficent cooling wise if everything is in good shape, so you have some room for personal discovery. Later
Old Sep 13, 2003 | 11:00 AM
javi2001's Avatar
javi2001
Well, it depends on switch location, remember temp. at engine block where gauge sender is locate is always 3 to 10ºF lower than temp read at t-stat elbow connection (Where EFI temp. sender is located) This is a typical behavior of inline engines 6L and 8L.
Regards;
Old Sep 14, 2003 | 02:53 AM
SPROCKET's Avatar
SPROCKET
Guess it really depends where you're installing the temp sensor and what you're using to measure the temperature. I installed both temp sensors before the water inlet on the readiator and used a laser thermometer to get the actual temp.
reed1951
29
Jun 27, 2018 07:50 PM
billyrayf150
Offroad & 4x4
Dec 24, 2015 08:49 PM
orangeford
18
Feb 27, 2015 03:24 PM
helpfulguy
30
Dec 6, 2012 03:04 PM
