Jack question for a beginner
Old Apr 9, 2008 | 04:17 PM
fordmotorline's Avatar
fordmotorline
Hello all, i'm going to purchase a hydraulic jack so I can do my brakes on my truck. I have an 05 supercrew, will a 3 1/4 ton jack be ok to use?
Old Apr 9, 2008 | 04:53 PM
Ryan50hrl's Avatar
Ryan50hrl
More than enough...make sure you purchase a GOOD set of jack stands as well, just using a jack is dangerous and NEVER acceptable. Also, what type of jack are you buying?
something like this
Craftsman 3 ton Floor Jack - Model 50136 at Sears.com
with a pair of these (actually i'd like bigger stands, more in the 6 ton range for added safety)
Craftsman 3 ton High Lift Jack Stands - Model 50159 at Sears.com
should do you just fine....
Old Apr 9, 2008 | 11:34 PM
fordmotorline
something like this
I was actually looking at this jack last weekend at Sears. Thanks for the advice
Old Apr 10, 2008 | 12:09 AM
mattd17's Avatar
mattd17
this is the exact jack that i have, and use all the time..... the only negative thing i can say about it is that it doesnt have the "one pump quick lift to chasis" feature.... since my truck is lifted, it takes a bit to reach it, so i usually use a block of wood in between the jack and truck to help out.
Old Apr 10, 2008 | 07:47 AM
Ryan50hrl's Avatar
Ryan50hrl
I used to do that with my 95 until the truck rocked a bit once and started falling off the block of wood.....lucky it had the stands under it and it didn't come all the way down.
micklskot
13
Dec 4, 2009 11:43 PM
modeleh
Apr 8, 2009 12:38 PM
papadelogan
Jan 31, 2009 12:43 PM
Rich in CO
Oct 8, 2006 09:02 AM
WhëëlMå1
1978 - 1996 Big Bronco
Dec 3, 2002 11:02 PM
