1978 - 1996 Big Bronco
'96 Bronco jacking points
Old Dec 3, 2002 | 06:46 PM
WhëëlMå1's Avatar
WhëëlMå1
Wheres the best place to jack on these vehicles?? Ive been jacking the axles, but my jack is a pain. Im concered with where to jack the front of the vehicle. I know some vehicles jack right behind the fender area. Thanks
Old Dec 3, 2002 | 06:55 PM
Big 89 Bronco's Avatar
Big 89 Bronco
Put your jack on the frame. Thats probably the best place.
Old Dec 3, 2002 | 07:35 PM
Goodsath's Avatar
Goodsath
Get a High Lift jack and use the bumper as your lifting point. A High Lift will also get you out of more tough spots than that twist jack.
Old Dec 3, 2002 | 08:38 PM
msuforeman's Avatar
msuforeman
Yeah---Go ahead and use a hi-lift on a 96 stock bronco bumpers and it will bend them. These bumpers are definitely not made to be used as jacking points. Stick with the frame or axles. Although it is good to own a hi-lift. Luckily I have custon sliders and bumpers so I can use a hi-lift on any corner as well as the sides.
Brian
Old Dec 3, 2002 | 10:44 PM
msuforeman's Avatar
msuforeman
Old Dec 3, 2002 | 11:02 PM
steve83's Avatar
steve83
The best places are the outer ends of each axle just inboard of the tires. If you look in the owner's manual or on a sticker on the core support, it'll show the recommended points. Don't use the bumpers or body.
scooterspal
26
Sep 18, 2018 07:50 PM
crawdad
2004 - 2008 F150
Jul 19, 2012 08:38 PM
harryakc
Nov 8, 2010 11:28 AM
bkaul
Sep 26, 2010 09:54 AM
